Re: X275 Build crank needed
[Re: W5DART66]
#1644005
07/08/14 04:21 PM
07/08/14 04:21 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Chad needs 4" crank ASAP
Chad wants to do this but parts are hard to find for SBM and it will be much less of a headach to put FORD or Chevy back in the dart.
I am doing all I can to help as I think his car with mopar in it would be bad a$$
Would like a callies crank.(Indy just sold last one they had)
I know this is not parts needed but I think more pople will see this .
Thanks MOPARTS
Brett
Brett try CrankShaft Specialties in Memphis. He had a couple a few months back.
[Re: rt66jim]
#1644008
07/08/14 05:04 PM
07/08/14 05:04 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
Thanks MOPARTS
Brett
Is Floyd Doug Rowe treating customers right now? He had a bad spell for a while.
http://www.ripoffreport.com/r/Crankshaft...d-openly-267378
[Re: Airwoofer]
#1644010
07/08/14 08:06 PM
07/08/14 08:06 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
this would be my first choich..I got mine in two or three weeks ... http://www.bing.com/search?q=King%27s+Crankshaft+Co&FORM=QSRE6 LATE MODLE STOCK" PART#802/CHRY This crankshaft is made from a raw E4340 forging with 2.100 rod journals and 2.499 main's. Crankshaft comes with 1/8 radius and nitride bearing surface, OD turned maxim round for low inertia and windge .Crank has bull nose "counterweights weights 50.5 lbs. *Hp range 900+ *STROKE 3.580 340/ CHRY LIGHT "REV" CRANKSHAFT PART#809/CHRY Machined from E4340 USA comes with CNC profiled counterweights,scalloped and bull nose for low inertia weight and improved acceleration.Crank weight 42 to 45lbs *Hp range 650 *stroke range 2.900 3.750 *not gun drilled ◦ Chevy oiling 340/ CHRY "CUP LITE" PART# 810/CHRY Machined from E4340 USA and intended for higher Hp application. More meat left in needed areas bull nose counterweights weighs in at 50 to 54lbs *Hp range 900+ *Stroke range 2.500 to 4.250 *not gun drilled 340/ CHRY LIGHT "REV" CRANKSHAFT PART#803/CHRY Machined from E4340 USA comes with CNC profiled counterweights,scalloped and bull nose for low inertia weight and improved acceleration.Note crankshaft weight 37lbs *Hp range 600 *stroke range 2.500 3.750 *not gun drilled *Rod journal size 1.889. or 1.850 or 1.771 ◦ 302 FORD MAINS 340/ CHRY GOLD SREIS LIGHT "REV" CRANKSHAFT PART#803/CHRY/GS Machined from E4340 USA comes with CNC profiled counterweights,scalloped and bull nose for low inertia weight and improved acceleration.Note crankshaft weight 34lbs *Hp range 600 *stroke range 2.500 3.750 *Rod journal size 1.889. or 1.850 or 1.771 *Gun drill mains *302 FORD MAINS
[Re: W5DART66]
#1644013
07/08/14 08:34 PM
07/08/14 08:34 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I saw a 4.250 Bryant on racinjunk the other day
[Re: fishy340]
#1644017
07/08/14 11:04 PM
07/08/14 11:04 PM
Quicktree
K1 = Chinese
top of the line China not scat china
[Re: Quicktree]
#1644018
07/08/14 11:21 PM
07/08/14 11:21 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
K1 = Chinese
Boy Quicktree....... I keep reading your posts, thinking maybe even one of them once in a while might be revelant.... But alas, no such luck
[Re: B3422W5]
#1644019
07/08/14 11:24 PM
07/08/14 11:24 PM
Quicktree
K1 = Chinese
well good for you, need to get a little sense of humor and you may understand.
[Re: Quicktree]
#1644020
07/08/14 11:30 PM
07/08/14 11:30 PM
B3422W5
Portage,michigan
K1 = Chinese
I have a great sense of humor. That is why I posted that. You gotta remember I have been reading your posts 10 or 15 years now
[Re: B3422W5]
#1644021
07/08/14 11:35 PM
07/08/14 11:35 PM
Quicktree
K1 = Chinese
and the statement was not only funny but true!
