Page 1 of 5 1 2 3 4 5
Scat or Eagle for I beam rods #1642389
07/05/14 09:30 PM
07/05/14 09:30 PM
Truckville, the capital of NY
85_Ram_4speed Offline OP
I generally like the Scat rods over the Eagles for engines I build, generally due to the better tolerances. But this one is a basic 340 rebuild, nothing fancy and will never be raced. Have the eagles improved at all in thier tolerances? They are about $70 less than the Scats and I am sure this gentleman would appreciate that.
Reasons for not wanting to use the stockers are bolts are $70 and to have the rods redone is $200. At $270, I can get the Eagles for the owner, and just be done---plus I really like using Cap bolt style rods.
Outcast Dodge guy.
Re: Scat or Eagle for I beam rods [Re: 85_Ram_4speed] #1642390
07/05/14 09:33 PM
07/05/14 09:33 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
The scat is made out of better material...
scat 4340
eagle 5140
but for a stock rebuild ...either one would probably do.
Tony
70 AARCuda Vitamin C
Re: Scat or Eagle for I beam rods [Re: 70AARcuda] #1642391
07/05/14 09:41 PM
07/05/14 09:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Neither, for a few bucks more get an H beam
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642392
07/05/14 09:43 PM
07/05/14 09:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats my opinion also
Re: Scat or Eagle for I beam rods [Re: MR_P_BODY] #1642393
07/05/14 09:48 PM
07/05/14 09:48 PM
Really, for essentially a stock rebuild? Seems like alot of overkill, But I'll take it into account.
Outcast Dodge guy.
Re: Scat or Eagle for I beam rods [Re: 85_Ram_4speed] #1642394
07/05/14 09:55 PM
07/05/14 09:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I wouldn't use them in a stock build. They suck
Re: Scat or Eagle for I beam rods [Re: 85_Ram_4speed] #1642395
07/05/14 09:56 PM
07/05/14 09:56 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
from this forum scat over eagle,already mentioned better material
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642396
07/05/14 10:10 PM
07/05/14 10:10 PM
Care to elaborate?
Outcast Dodge guy.
Re: Scat or Eagle for I beam rods [Re: 85_Ram_4speed] #1642397
07/05/14 10:15 PM
07/05/14 10:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Care to elaborate?
I've seen many rip in half... but you can do what you
want
Re: Scat or Eagle for I beam rods [Re: MR_P_BODY] #1642398
07/05/14 10:17 PM
07/05/14 10:17 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
you have seen scat 4340 I beam rods rip in half?
Tony
Re: Scat or Eagle for I beam rods [Re: 85_Ram_4speed] #1642399
07/05/14 10:24 PM
07/05/14 10:24 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
My ...
My first experience with SCAT I Beams: 250 +/- runs in a 12:1 416, low 10's @ 3100#...6800-7000 at the stripe every run. We lost a couple of rod bearings due to oil detonation, and those rods were "blued" from the heat and out of spec obviously. But the other 6 were within spec that a resize would have made them reusable.
I have heard of many failures with Eagle I beams, though never ran them myself.
Your dead on about the cost or remanning a set of 40 year old OE rods vs, the SCATs. Better material, cap screws and much lighter than the OE rods.
SCAT's are going in a warmed up 340 I'm doing for a guy right now and will be in my street/strip small block for sure.
Re: Scat or Eagle for I beam rods [Re: 85_Ram_4speed] #1642400
07/05/14 10:34 PM
07/05/14 10:34 PM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
I saw a scat rod I like a tie and not broke .... If I can choose, scat.
Re: Scat or Eagle for I beam rods [Re: 70AARcuda] #1642401
07/05/14 10:37 PM
07/05/14 10:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They were Scat I beams... thats all I know but they
were in 2 halves.. I know nothing else about what
rpm or anything
Re: Scat or Eagle for I beam rods [Re: MR_P_BODY] #1642402
07/05/14 10:45 PM
07/05/14 10:45 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Got two sets in use, and will use them again..
Tony
Re: Scat or Eagle for I beam rods [Re: 70AARcuda] #1642403
07/05/14 11:31 PM
07/05/14 11:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All I use are H-beams.. I bought a few sets of Eagles
years ago and thats what are in all my engines.. but
I have heard the quality went down a couple years back
Re: Scat or Eagle for I beam rods [Re: 70AARcuda] #1642404
07/06/14 01:10 AM
07/06/14 01:10 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Not a problem using scat I beams here. Especially in a stock rebuild situation. H beams are a wasteful overkill deal.
Eagle SIR's had lots of problems in the past.
Re: Scat or Eagle for I beam rods [Re: RobX4406] #1642405
07/06/14 01:19 AM
07/06/14 01:19 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
The little enginemaster's 318 I am fixing to put in my Duster has Scat I beam 6.20 Chevy rods in it. I will find out here soon if those rods are pretzel's or not.
They are part of a real light spinning Assy. So I hope they are fine.
Can't imagine a little 318 hurting them..
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Scat or Eagle for I beam rods [Re: RobX4406] #1642406
07/06/14 01:23 AM
07/06/14 01:23 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I have a set of SIR rods that you can have for shipping haha after breaking the Eagle cast crank I'm done with their budget items. I'm planning to hang them up as garage art.. You just have to trade me some good mopar garage art to hang up
The held up to around 400hp 400tq for a bunch of years- strong enough to break my crank! No spun bearings...
Re: Scat or Eagle for I beam rods [Re: 70AARcuda] #1642407
07/06/14 08:33 AM
07/06/14 08:33 AM
Q
Quicktree Offline
Quicktree  Offline
Q
keep using them and good luck, it's about cost and quality for the extra few bucks to go H beam it's a no brainier. How many sets have we seen on here turn out bad? You can see the poor quality by looking at them.
Re: Scat or Eagle for I beam rods [Re: B3422W5] #1642408
07/06/14 08:34 AM
07/06/14 08:34 AM
Q
Quicktree Offline
Quicktree  Offline
Q
you are a brave man
