World hemi block ? #1640786
07/01/14 07:41 PM
07/01/14 07:41 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Can anyone tell me about the world hemi block that they used to sell that was 4.190 bore? If you bore it to 4.25 you loose .060 cly wall thickness right at the start. They say max bore is 4.310 so that is only a .060 over motor. It that typical of all the world product blocks except the 4.500 blocks. I thought the old MP blocks could go a lot bigger than .060 over.
Re: World hemi block ? [Re: fastmark] #1640787
07/01/14 07:44 PM
07/01/14 07:44 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
The MoPar block was the 4.19 bore.
Re: World hemi block ? [Re: Handygun] #1640788
07/01/14 08:06 PM
07/01/14 08:06 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
So if it is a world product P5153942, according to their website, It is a 4.240 rough bore. How big do those go safely?
Re: World hemi block ? [Re: fastmark] #1640789
07/04/14 01:06 AM
07/04/14 01:06 AM
mi
dirty magnum Offline
mi
they say 4.700
Re: World hemi block ? [Re: dirty magnum] #1640790
07/04/14 02:29 AM
07/04/14 02:29 AM
they say 4.700
I don't think so I have one of the World Hemi blocks that is rough bored to around 4.494, I think. I did use one of the older Mopar replacement blocks that was 4.184 rough bore or so and it was thin after sonic testing it. I was building a street blower motor so we went to 4.250 with a 4.375 stroke crank so the customer would have room for more work if he scored a piston or cylinder later on OP, if you want large C.I. and reliability buy a better block to start with
Re: World hemi block ? [Re: Cab_Burge] #1640791
07/04/14 03:06 PM
07/04/14 03:06 PM
Lost in the 70's
440gtx6 Offline
440gtx6  Offline
Lost in the 70's
they say 4.700
Well according to World's website the cast iron blocks use the same casting, WOR-426 regardless of shipped bore size. The document also says they can all be bored to max of 4.60. As with any block though it should be sonic tested before machining.
World Block
69 EF8 GTX 440 auto
72 EB5 RR/GTX 440 auto
70 EW1 GTX 440-6 4 spd
70 EF8 Satellite 318 auto (452 coming soon)
70 FK5 Satellite 318 auto
71 FC7 Cuda 340 4 spd
Re: World hemi block ? [Re: Cab_Burge] #1640792
07/04/14 08:00 PM
07/04/14 08:00 PM
mi
mi
mopar performance claims that, talked to them this winter
Re: World hemi block ? [Re: 440gtx6] #1640793
07/05/14 12:30 AM
07/05/14 12:30 AM
they say 4.700
World Block
What I read was that one iron block casting can be bored to 4.600, not all of them I wouldn't even consider boring one of those blocks that big without a thorough inspection including a good sonic test
