Re: 70Lime Green Paint
[Re: 493 Stroked]
#1639992
06/29/14 01:09 PM
06/29/14 01:09 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Does anybody have or can get the paint mix for lime green for 1970. My car has been at the body shop for 3 months and they cant find how to mix the paint. I need HELP!!! Thanks
Not surprising, first, as mentioned, what paint line/mfg are you/body shop intending to use, 2nd what type of paint finish is intended for your vehicle?, single stage enamel, Urethane, base coat/clear coat, etc, etc, is this a Plymouth or Dodge model?
Mike
[Re: 493 Stroked]
#1639996
06/29/14 03:51 PM
06/29/14 03:51 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The car is a Duster and it will be base /clear and I can get just about any brand I just need the code to get it mixed. Thanks Guys.
Hmmmm...if it was that easy, for starters you reference the original PPG paint chart as they were the original supplier (posted below) that will yield you the PPG codes J-5 that Chrysler used, then the code PPG uses for ID, code # 2128, back in the day this would be broken down to 2 ALTs based on Dodge or Plymouth use
Today the Computer/mix programs have been tailored to eliminate most if not all the ALTs, having only one formulation, or matching the original color/formulation to the closet in the program that meets VOC compliance....if your using PPG 2128 BC/CC, ALT 1 will be the closest match for 1970 Plymouth LimeLight ALT1....this color was reformulated by PPG/Ditzler in 2000 to Limelight Poly #2853,...It may have been reformulated again due to changing VOC compliance
the following paint codes for LimeLight are for their respective brands, as you have not narrowed down a paint mfg/type
PPG 2128 ALT 1 Dupont 5181L,5181A,5181D,5181K,5181K H, all ALT1 Acme Rodgers 11054 Martin Senour 1888 Sherwin Williams 3194
There's many more depending on MFG's
Personally if your going BC/CC, I'd recommend Dupont ChromaBase 5181K H ALT 1 for Plymouth LimeLight, and use the recommend value shade for the primer base/sealer as this will effect the final outcome of the color
