70Lime Green Paint #1639989
06/29/14 05:38 AM
06/29/14 05:38 AM
Ohio
493 Stroked Offline OP
Ohio
Does anybody have or can get the paint mix for lime green for 1970. My car has been at the body shop for 3 months and they cant find how to mix the paint. I need HELP!!! Thanks
Re: 70Lime Green Paint [Re: 493 Stroked] #1639990
06/29/14 09:02 AM
06/29/14 09:02 AM
SE Pa.
LimeliteAero Online content
LimeliteAero  Online Content
SE Pa.
Thanks for opening up an old wound!
Do you know what brand or if theyre using single stage or BC/CC?
Re: 70Lime Green Paint [Re: 493 Stroked] #1639991
06/29/14 09:22 AM
06/29/14 09:22 AM
michigan
70 buzz Offline
70 buzz  Offline
michigan
image [year] manuf model paint color name code sample Chrysler code Ditzler PPG Dupont Acme Rogers Martin Senour Sherwin Williams comment
G B Y 1970 Chrysler Plymouth Lime Green F4 B C X DT7738 2133 5085L, 5085A, 5085D 5762 1881 2941
Re: 70Lime Green Paint [Re: 493 Stroked] #1639992
06/29/14 01:09 PM
06/29/14 01:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Not surprising, first, as mentioned, what paint line/mfg are you/body shop intending to use, 2nd what type of paint finish is intended for your vehicle?, single stage enamel, Urethane, base coat/clear coat, etc, etc, is this a Plymouth or Dodge model?
Mike
Re: 70Lime Green Paint [Re: 493 Stroked] #1639993
06/29/14 02:38 PM
06/29/14 02:38 PM
Ohio
Ohio
The car is a Duster and it will be base /clear and I can get just about any brand I just need the code to get it mixed. Thanks Guys.
Re: 70Lime Green Paint [Re: 493 Stroked] #1639994
06/29/14 02:50 PM
06/29/14 02:50 PM
Kirkland, Washington
Pacnorthcuda Offline
Assuming by "lime green" you are referring to sublime/limelight, the codes can be found in this link
http://paintref.com/cgi-bin/colorcodedisplay.cgi?color=Sublime
Re: 70Lime Green Paint [Re: Pacnorthcuda] #1639995
06/29/14 03:46 PM
06/29/14 03:46 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
https://www.carpaintonline.com/paints-byoem.php?PPGCode=2128&PNId=4166&OEMCode=j5
Looks like these guys have multiple options. No idea of the quality or match but it's somewhere to start.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: 70Lime Green Paint [Re: 493 Stroked] #1639996
06/29/14 03:51 PM
06/29/14 03:51 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Hmmmm...if it was that easy, for starters you reference the original PPG paint chart as they were the original supplier (posted below) that will yield you the PPG codes J-5 that Chrysler used, then the code PPG uses for ID, code # 2128, back in the day this would be broken down to 2 ALTs based on Dodge or Plymouth use
Today the Computer/mix programs have been tailored to eliminate most if not all the ALTs, having only one formulation, or matching the original color/formulation to the closet in the program that meets VOC compliance....if your using PPG 2128 BC/CC, ALT 1 will be the closest match for 1970 Plymouth LimeLight ALT1....this color was reformulated by PPG/Ditzler in 2000 to Limelight Poly #2853,...It may have been reformulated again due to changing VOC compliance
the following paint codes for LimeLight are for their respective brands, as you have not narrowed down a paint mfg/type
PPG 2128 ALT 1
Dupont 5181L,5181A,5181D,5181K,5181K H, all ALT1
Acme Rodgers 11054
Martin Senour 1888
Sherwin Williams 3194
There's many more depending on MFG's
Personally if your going BC/CC, I'd recommend Dupont ChromaBase 5181K H ALT 1 for Plymouth LimeLight, and use the recommend value shade for the primer base/sealer as this will effect the final outcome of the color
