Traction Issues...AGAIN !!! UPDATE*****
#1637756
06/23/14 10:37 PM
06/23/14 10:37 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Car was hooking hard at the end of last season. CalTrac's were set at no preload left side and 2 flats on the right.....Ranchos on #6. Car left straight and was dead hooking. So why screw with it/.....right ??? Well...over the winter I took the Six Pack off and changed over to a Victor and a 950 Quick Fuel. This weekend, I couldn't get any hook at all.....just blazing the slicks well out past the 60 and most of the time back peddling to staightn the car out. I tried less shock....more shock...a bit more preload and still no results. To coin the phrase...WTF ???
Re: Traction Issues...AGAIN !!!
[Re: superwrench]
#1637759
06/24/14 01:30 AM
06/24/14 01:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm going to say about 40. But there was NO signs of them going away....They hooked right thru till the end of last season, then the car's been parked. Can they "dry" up like that ???
Yes they can dry up BUT its usually in the sun that really hurts them... in the garage on stands is normally no problem
[Re: superwrench]
#1637761
06/24/14 03:17 AM
06/24/14 03:17 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
let us know how it works out and good luck
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: pittsburghracer]
#1637764
06/24/14 07:56 AM
06/24/14 07:56 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I used to get over 100 passes out of my 32x14's on a 4 link car.
My 10.5 tire ladder bar Dart would eat slicks in 25 passes.
[Re: dvw]
#1637766
06/24/14 09:18 AM
06/24/14 09:18 AM
Posts: 1,178 Indy
FlyFish
Indy
If it was spinning that bad, I would say it is track prep...or lack there of.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#1637767
06/24/14 10:14 AM
06/24/14 10:14 AM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
I would have to agree with this. And if you decide to get rid of the old slicks let me know, I know I could hook with them.
[Re: superwrench]
#1637770
06/24/14 11:27 AM
06/24/14 11:27 AM
Posts: 167 maryland
74yellowduster
maryland
.Ranchos on #6. Car left straight and was dead hooking. So why screw with it/.....right ??? .... I tried less shock....more shock...a bit more preload and still no results. To coin the phrase...WTF ???
how old are the ranchos?
[Re: Crizila]
#1637772
06/24/14 12:57 PM
06/24/14 12:57 PM
Triple Threat
Renton Washington
Given that I know where you race, and track prep if we want to call it that leaves something to be desired, I wouldn't go tossing the slicks out just yet. How many races have been held this year and how was the track for others?
[Re: Triple Threat]
#1637773
06/24/14 01:44 PM
06/24/14 01:44 PM
superwrench
A few guys were having some hook issues, but most I talked too said it seemed to be pretty good. It was the first race weekend. This car was 60'-ing at 1.45 to 1.47 last season. Best to date is a 1.517 on a 6.87 1/8th pass. I know for a fact that with this carb and intake combo change, the car seems to really hit hard then releases...... harder than with the six pack. And yes...the shocks are 5 years old...I was thinking about that....maybe I should just crawl under there and change them too. But then, the ride was just as hairy with them at #9 as it was with them at #3.....you would have thought that if it is shock problems, that there would have been a setting in there that should have worked better . One thing I didn't do was to put in tubes when I went to these tires....maybe I've hit the sidewalls so hard last season that they can't put up with the abuse anymore !!
[Re: superwrench]
#1637774
06/24/14 01:54 PM
06/24/14 01:54 PM
MR_P_BODY
Heavier cars that hit the tire hard kill the side walls much sooner than lighter cars... I've never worn out a slick(tread surface) but the side walls are done
[Re: MR_P_BODY]
#1637775
06/24/14 01:56 PM
06/24/14 01:56 PM
superwrench
Try this pic....I think THIS tells the story !!!
A fellow racer just sent me this.....maybe hard to see at this sizing, but on a larger pic, the sidewalls are DESTROYED....and with pressure at 14# !!
