Proper way to fill new brake system with fluid? #1637069
06/22/14 05:55 PM
06/22/14 05:55 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I have manual brakes on a 72 Duster, drum in the rear and Strange disc brakes up front with a modern style master cylinder with the 2 plastic caps that twist-on, and all brand new brake lines.
Do I just fill the master cylinder and let it gravity feed the lines over night, and bleed them the next day? Or is it more complicated than that?
My Strange front discs are the 4-piston type so I have to bleed the 2 on top and then flip it around and bleed the other 2.
Re: Proper way to fill new brake system with fluid? [Re: ProSport] #1637070
06/22/14 07:17 PM
06/22/14 07:17 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Bench bleed the master cylinder, then just pressure bleed at the RR, then LR, then RF, then LF. The pump up, open bleeder, pedal to floor, close bleeder method. Use a glass jar and some clear hose so you can see the air leaving.
I don't think you'll have to let it gravity bleed overnight. Shouldn't take all that long to get a good pedal.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Proper way to fill new brake system with fluid? [Re: goldduster318] #1637071
06/22/14 07:27 PM
06/22/14 07:27 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Ok, I already have the master cylinder filled with fluid, so I'll need to syphon that out and disconnect the lines, and unbolt it from the firewall.
Is there a certain procedure to bench bleeding?
Re: Proper way to fill new brake system with fluid? [Re: ProSport] #1637072
06/22/14 07:32 PM
06/22/14 07:32 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if you have a helper you can 'bench bleed' it installed. you didn't bleed it before installing it? it should have come with 2 plastic fittings and small lengths of hose, Yes??
Re: Proper way to fill new brake system with fluid? [Re: mikemee1331] #1637073
06/22/14 07:52 PM
06/22/14 07:52 PM
Lake Orion, MI
Lake Orion, MI
I use plugs and then just push the pushrod in and out on the bench until I can't see air coming out of the ports anymore. I suppose you could do this on the car, but it's going to be a bit harder. If you did it my way, it can be like a fluid geyser coming out of the MC anyway, and you don't want that on your paint.
That looks to me like a 1 1/8" MC. I hope not, if it is, you'll have a super stiff pedal and not very responsive brakes. I highly recommend the 15/16" one from Dr. Diff or you can use the stock size 1 1/32", which will be decent as well. With the Organic pads and the 15/16 MC (and the 11.75" brakes), my car will jerk you right through the windshield without having to give it all of your might to stop.
Re: Proper way to fill new brake system with fluid? [Re: mikemee1331] #1637074
06/22/14 08:19 PM
06/22/14 08:19 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
No, I bought this car as a project car that was in the very early stages of building. Everything is hooked up and I am not a mechanic so I didn't know about bench bleeding the master cylinder.
Re: Proper way to fill new brake system with fluid? [Re: ProSport] #1637075
06/22/14 08:37 PM
06/22/14 08:37 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Go to YouTube and search for bench bleeding master cylinder. Plenty of videos.
Re: Proper way to fill new brake system with fluid? [Re: kentj340] #1637076
06/22/14 08:43 PM
06/22/14 08:43 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.youtube.com/watch?v=kEPXgDGU6_0
you can do this with master cylinder bolted into the car..
Tony
70 AARCuda Vitamin C
Re: Proper way to fill new brake system with fluid? [Re: 70AARcuda] #1637077
06/22/14 08:57 PM
06/22/14 08:57 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
But don't spill a single drop of brake fluid on your nice new paint!!!
Re: Proper way to fill new brake system with fluid? [Re: kentj340] #1637078
06/22/14 09:12 PM
06/22/14 09:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I restored my 63 I did the complete brake system including getting a full brake pedal myself. I bench bleed the M/C before I put it on and then let the cylinders all gravity bleed at each wheel. After they did I close them up and pump the pedal and then gravity bled them all again. Still have a full pedal to this day and that was in 2006. I always gravity bleed first as it may not get you a full pedal all the time but it always helps so you dont have to have someone pump the pedal as much as they would if I did not gravity bleed. Ron
Re: Proper way to fill new brake system with fluid? [Re: ProSport] #1637079
06/23/14 01:33 AM
06/23/14 01:33 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I just bought a hydraulic brake bleeder from Harbor Freight.
Works great and comes with a fluid container to refill the reservoir while you bleed them.
http://www.harborfreight.com/brake-fluid-bleeder-92924.html
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Proper way to fill new brake system with fluid? [Re: finadk] #1637080
06/23/14 02:00 AM
06/23/14 02:00 AM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
I think if you use dot 5 silicone fluid your paint will be safe. You will never have any moisture problems in the future with dot 5.
Re: Proper way to fill new brake system with fluid? [Re: ProSport] #1637081
06/23/14 01:00 PM
06/23/14 01:00 PM
"bench" bleeding is a misnomer stemming from when people sometimes bled the MC ahead of time on the bench likely secured in a vise. Bench bleeding means that you dont jus pour fluid into the MC then bleed out the wheels but instead you bleed out the MC by itself first either on the bench or on the car then do the corners.I do it with the MC installed on the car rather than on the "bench" as is too likely to spill fluid when your done till it is carried/installed on the firewall. Get the kit at your parts house that consists of 2 blue plastic male fittings that screw into the MC ports & 2 short pieces of black tubing that connect to the fittings & run up several inches & around into the bowls & there's a clip that holds em in place. Put a block of wood of the proper thickness under the brake pedal so you do not push the MC cups past their normal travel then reasonably slowly push the pedal in/out maybe 20 strokes & I like to have a helper do the pedal & me watching the MC so the hoses stay put etc. then when done hookup the steel lines & bleed out the corners in order as described (keep the block under the pedal). Dont let the MC get low. I wrap a large bath towel under the MC/lines to catch any fluid mess
Re: Proper way to fill new brake system with fluid? [Re: RapidRobert] #1637082
06/23/14 11:32 PM
06/23/14 11:32 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
It's explanations like this that makes life so much easier for dummies like me. Thank you sir!
I'm gonna buy the Wilwood master cylinder bleeder kit #WIL-260-11593 for $9.96 and bleed it tomorrow night.
