need alternator mount on 440 with meziere elec pump #1635602
06/19/14 02:11 PM
06/19/14 02:11 PM
440dustr Offline OP
440dustr  Offline OP
I just picked up a meziere electric water pump for my 440 and before I install it I need to locate a mount for my alternator since the mount I am currently using uses one of the threaded holes in the stock water pump housing that the electric pump doesn't have. Does anyone know of a bracket that will work. Billet aluminum if possible but at this point I cant be to picky. thanks
Re: need alternator mount on 440 with meziere elec pump [Re: 440dustr] #1635603
06/19/14 02:17 PM
06/19/14 02:17 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Do you have the room for a low mount? Also now might be the time to switch to a smaller and lighter internal regulator unit ?
Re: need alternator mount on 440 with meziere elec pump [Re: JohnRR] #1635604
06/19/14 02:24 PM
06/19/14 02:24 PM
440dustr Offline OP
440dustr  Offline OP
I have a new 140 amp powermaster chrome 1 wire CS130 style alternator. I may have the room for lower mount just cant find one that will bolt up to the alternator that I have. I am trying not to have to buy a new one.
Re: need alternator mount on 440 with meziere elec pump [Re: 440dustr] #1635605
06/19/14 02:55 PM
06/19/14 02:55 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Had a friend that ran 1 of those pumps. He couldnt keep his engine cool on the street. The pump didnt flow enoigh water at speed. Worket great at the strip tho..
I am truckless..
Re: need alternator mount on 440 with meziere elec pump [Re: 340SHORTY] #1635606
06/19/14 03:09 PM
06/19/14 03:09 PM
440dustr Offline OP
440dustr  Offline OP
I am hoping it helps with my car
I don't drive it much but when I do and if I get stuck in traffic or long light I can get it up to 210ish
I have a large aluminum rad, elec fan, 180 thermostat.
my hopes are that it keeps it cooler at the lower rpm.
Its a blown 440 and I even switched from 456 gears to 355 and that helped some highway driving.
Re: need alternator mount on 440 with meziere elec pump [Re: 440dustr] #1635607
06/19/14 07:47 PM
06/19/14 07:47 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My friends car with that pump on a hemi can't keep it under 210 degrees his dads hemi car with reg pump runs 160 in the heat, your choice. Someone makes a bracket kit for that pump, the son has it on his, goes in the stock location. I can't convince him to change it out, he says it looks pretty.
