Thermoquad ID help please. #1635361
06/18/14 04:59 PM
06/18/14 04:59 PM
Charlotte, NC
Orange_Crush Offline OP
Belieber!
Belieber!
Charlotte, NC
So...while cleaning out the black hole known as a "utility room" in my house, I stumbled upon a Carter Thermoquad carb...
Which is odd because I have NEVER owned a car with a TQ on it...NEVER! I have no idea where this thing came from and I can only figure that, somewhere out in the multiverse, my doppelganger has found a pristine Hemi AFB in his incredibly neat and well-organized utility room.
In any case, I took a bunch of pics...neglecting (of course)to photograph the numbers of the bloody thing so, I'm hoping that...possibly, someone here can do a sight ID on it so I know what I have. Can anyone ID this thing?
Here is pic 1
1970 Dodge Charger R/T Hemi Orange U-code 4-speed
1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
Re: Thermoquad ID help please. [Re: Orange_Crush] #1635362
06/18/14 05:00 PM
06/18/14 05:00 PM
Charlotte, NC
Belieber!
Belieber!
Charlotte, NC
underside
Re: Thermoquad ID help please. [Re: Orange_Crush] #1635363
06/18/14 05:22 PM
06/18/14 05:22 PM
IMGTX Offline
IMGTX  Offline
My 73 looked exactly like that some of the later models have a flat pad or even a valve on the flat pad on the front center of the top aluminum housing.
The size of the primaries determine if it is a 700 or 800 cfm series.
The Thermo-Quad was available with two primary throttle bore sizes, 1-3/8"
and 1-1/2". Flow ratings (CFM) vary depending on the source, but
the TQs with the 1-3/8" bores are listed as 750-800 CFM and those with the
1-1/2" primary throttle bores are rated at 800-850 CFM
This is what what a 71 looks like. Notice the idle screws.
If you are interested in selling it and it is either a 73 340 4speed or 74 440 HP carb please PM me.
Re: Thermoquad ID help please. [Re: IMGTX] #1635364
06/18/14 05:34 PM
06/18/14 05:34 PM
IMGTX Offline
IMGTX  Offline
After comparing pics of a 340 carb to yours I believe it is a big block carb this is the primaries on a 340 carb.
Re: Thermoquad ID help please. [Re: IMGTX] #1635365
06/18/14 05:50 PM
06/18/14 05:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There should be numbers on the front of the base plate corner.
Re: Thermoquad ID help please. [Re: Orange_Crush] #1635366
06/18/14 05:57 PM
06/18/14 05:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I use this website when it comes to thermoquads, maybe it will help you?
web page
Re: Thermoquad ID help please. [Re: stumpy] #1635367
06/18/14 08:15 PM
06/18/14 08:15 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually on a T/Q they are on the back !
Re: Thermoquad ID help please. [Re: Orange_Crush] #1635368
06/18/14 09:08 PM
06/18/14 09:08 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The 4 digit number followed by an "S" will be stamped into the face of the rear drivers side mounting foot. The date code will also be stamped there (usually 3 digit day of year and one digit for the year)
Re: Thermoquad ID help please. [Re: 62maxwgn] #1635369
06/19/14 12:34 AM
06/19/14 12:34 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
OOPs! you are right. Old timers does it again.
Re: Thermoquad ID help please. [Re: Orange_Crush] #1635370
06/21/14 01:21 PM
06/21/14 01:21 PM
IMGTX Offline
IMGTX  Offline
This is 71-74 numbers.
The Great Carter Thermoquad Numbers Decode List
The letters listed under Models refer to carline (First letter of VIN)
Number Year Engine Trans Remarks Models
4972S 1971 340 Manl VLBJRW
4973S 1971 340 Auto VLBJRW
6090S 1972 400 Auto RWPD
6138S 1972 340 Manl VLBJRW
6139S 1972 340 Auto VLBJRW
6140S 1972 400 Manl HP RW
6165S 1972 400 Manl HP w/air pump RW
6166S 1972 400 Auto HP w/air pump RW
6212S 340 MARINE
6318S 1973 340 Manl VLBJRW
6319S 1973 340 Auto VLBJRW
6320S 1973 400 Manl HP RW
6321S 1973 400 Auto HP RWPD
6322S 1973 440 Auto LP PDCY
6324S 1973 440 Manl HP RWPDC
6339S 1973 340 Manl w/N98 VLBJRW
6340S 1973 340 Auto w/N98 VLBJRW
6341S 1973 400 Manl HP w/N98 RW
6342S 1973 400 Auto HP w/N95-N98 RWPD
6394S 1972 340 Auto Export L
6410S 1973 440 Auto LP w/N98 PDCY
6411S 1973 440 Auto HP w/N95-N98 RWPDC
6452S 1974 360 Manl HP VLBJRW
6453S 1974 360 Auto HP VLBJRW
6454S 1974 360 Manl HP Calif VLBJRW
6455S 1974 360 Auto HP Calif VLBJRW
6456S 1974 400 Manl HP RW
6460S 1974 440 Auto LP Early PDCY
6461S 1974 440 Auto LP Calif Early PDCY
6462S 1974 440 Auto HP Early RWPDC
6463S 1974 440 Auto HP Calif Early RWPDC
6488S 1974 360 Auto RWPDC
6489S 1974 400 Auto HP Early RWPDC
6503S 1974 400 Auto HP Export W
9000S 1974 318 Both Export D
9013S 1974 360 Auto Late RW
9014S 1974 400 Auto HP Late RWPDC
9015S 1974 440 Auto HP Late RWPDC
9016S 1974 440 Auto HP Calif Late RWPDC
9023S 1974 440 Auto LP Late PDCY
9024S 1974 440 Auto LP Calif Late PDCY
9801S 1974 383 Auto Perf & Off road 800 CFM
