Heat and Air #1635010
06/17/14 10:57 PM
06/17/14 10:57 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
Looking to put a heat and air unit in the Plymouth pick up. Anyone running the v pump or are they a waste of time? Working on a budget so if there are any deals out there post them up!
Re: Heat and Air [Re: moparpollack] #1635011
06/17/14 11:20 PM
06/17/14 11:20 PM
moparx Offline
moparx  Offline
the round "sanden" type compressor is easier to package than the old v type pump, plus it is almost half as heavy. all the heat/ac kits offered for retrofit are packaged with the sanden pump for those reasons. unless you are restoring something, the new pump is the way to go. also, unless you are real handy at fabbing stuff, the kits are the only way to go. you will be time and money ahead. there are tons of little things needed to make a "mix-n-match" system work. just my opinion.
Re: Heat and Air [Re: ] #1635013
06/23/14 09:55 PM
06/23/14 09:55 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
if on a budget a geo metro heater/ac box may be the cheapest pickapart unit to get...
Re: Heat and Air [Re: savoy64] #1635014
06/24/14 12:15 AM
06/24/14 12:15 AM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
What is so wonderful about those units? Any other late model stuff that makes sense to swap into a rod?
Re: Heat and Air [Re: Flipper1938] #1635015
06/24/14 03:16 AM
06/24/14 03:16 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
the old V type robs a lot of horse power,,get a complete system from a donor car or truck,,,and adaprt it to fit,,,may cost a lot less in the long run a friend of mine is gonna do hat in a 40 ply coupe,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Heat and Air [Re: fstfish66] #1635016
06/25/14 12:16 AM
06/25/14 12:16 AM
85086
Lil Herman
Lil Herman
85086
Update....Randy at Bouchilon Performance is hooking me up with a compressor and brackets. A friend is a dealer of old air products and I am going with a hurricane unit that mounts to the firewall.
The geo metro is a great hvac unit but you just can't find them.
It's more expensive to go this way but it's only money!
Re: Heat and Air [Re: Flipper1938] #1635017
06/25/14 12:20 AM
06/25/14 12:20 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I suspect since the Geo Metro is a small car low power car, the unit under the dash, and the ac compressor would both be rather small. Gene
Re: Heat and Air [Re: poorboy] #1635018
06/25/14 12:22 AM
06/25/14 12:22 AM
85086
Lil Herman
Lil Herman
85086
These were popular in Phoenix back in the day. The compressor is the size of a starter and you can mount them low.
Re: Heat and Air [Re: Flipper1938] #1635019
07/01/14 12:44 AM
07/01/14 12:44 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
they are in a compact easy to use box like vintage air....
Re: Heat and Air [Re: poorboy] #1635020
07/01/14 01:32 AM
07/01/14 01:32 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I got a question, can the compressor and evaporator be too big for the under dash unit? In others words can you mix and match or does it need to be a matched package?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Heat and Air [Re: AZ_A12_BEE] #1635021
07/01/14 12:38 PM
07/01/14 12:38 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
yes they need to match and somewhere there must be a formula----mopar and ford have had the most success--and gm under duress will blow hot air ---dont know how suzuki stacks up....
