Caliper hoses leaking #1634985
06/17/14 10:11 PM
06/17/14 10:11 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Doing a Disc brake conversion on my 64 Plymouth.Having trouble getting the hoses to seal.using the brass washers on each side of the bolt,but there still leaking.What am I missing?Calipers are sliders.
Re: Caliper hoses leaking [Re: gts1] #1634986
06/17/14 10:14 PM
06/17/14 10:14 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Using new or old washers?? I've always fought with new washers to get them to seal. I have a drawer full of new ones because I always end up using the old ones over.
Re: Caliper hoses leaking [Re: gts1] #1634987
06/17/14 10:23 PM
06/17/14 10:23 PM
make sure the washer on the bottom between the calipar and the banjo hose is thick enough so the banjo is above the deck and that those interface surfaces are squeaky clean/no debris. The smooth washers supplied with rebuilt calipers are leak prone & the best is to use some OE ones (even used ones) that have circular ribs like rings on a tree trunk cuz they seal good & I think Ma may even still have em available
Re: Caliper hoses leaking [Re: gts1] #1634988
06/17/14 10:24 PM
06/17/14 10:24 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Just went thru this with this, the washers that came with my hoses were paper thin and the hose bottomed on the caliper before they sealed.
Luckily the calipers came with nice thick ones.
I've had to use old ones before.
Re: Caliper hoses leaking [Re: Dcuda69] #1634989
06/18/14 12:20 AM
06/18/14 12:20 AM
God's Country Maryland
GODSCOUNTRY340 Offline
:agree:
I could not get the new ones to seal either.
Re: Caliper hoses leaking [Re: GODSCOUNTRY340] #1634990
06/18/14 12:59 AM
06/18/14 12:59 AM
BDW Offline
BDW  Offline
Re: Caliper hoses leaking [Re: BDW] #1634991
06/18/14 01:56 AM
06/18/14 01:56 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You'd be suprised to know the age of that article...How those washers are still being thrown in the box after all the complaints are anyone's guess...
Re: Caliper hoses leaking [Re: screamindriver] #1634992
06/18/14 08:16 AM
06/18/14 08:16 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran into that problem back in the early 90s at the shop.I just started using the old washers.Its strange that some are thick and some thin when you buy new parts.Rocky
Chrysler Firepower
Re: Caliper hoses leaking [Re: therocks] #1634993
06/18/14 12:20 PM
06/18/14 12:20 PM
I just called Ma & they are still available (pricey tho). they told me $4.25 ea which is full retail & I'm sure you could likely get em at a better rate
Re: Caliper hoses leaking [Re: RapidRobert] #1634994
06/18/14 01:49 PM
06/18/14 01:49 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Thanks Guys,
I just ordered them up from the dealer.About fell on the floor when he told me 4.25 each.
Re: Caliper hoses leaking [Re: gts1] #1634995
06/18/14 02:00 PM
06/18/14 02:00 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Also, a lot of times when installing anything that uses a soft copper or dead soft aluminum washer, I tighten and loosen and tighten and loosen the fitting at least a half dozen times to get them to bed together. I've eliminated a lot of leaking fittings this way.
Re: Caliper hoses leaking [Re: jbc426] #1634996
06/18/14 06:27 PM
06/18/14 06:27 PM
very good tip that I am gonna try (not on brake banjo fittings tho), I'll stick to ribbed washers for that
