Re: Caliper hoses leaking
[Re: gts1]
#1634987
06/17/14 10:23 PM
06/17/14 10:23 PM
RapidRobert
make sure the washer on the bottom between the calipar and the banjo hose is thick enough so the banjo is above the deck and that those interface surfaces are squeaky clean/no debris. The smooth washers supplied with rebuilt calipers are leak prone & the best is to use some OE ones (even used ones) that have circular ribs like rings on a tree trunk cuz they seal good & I think Ma may even still have em available
[Re: BDW]
#1634991
06/18/14 01:56 AM
06/18/14 01:56 AM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
You'd be suprised to know the age of that article...How those washers are still being thrown in the box after all the complaints are anyone's guess...
[Re: screamindriver]
#1634992
06/18/14 08:16 AM
06/18/14 08:16 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I ran into that problem back in the early 90s at the shop.I just started using the old washers.Its strange that some are thick and some thin when you buy new parts.Rocky
Chrysler Firepower
[Re: therocks]
#1634993
06/18/14 12:20 PM
06/18/14 12:20 PM
RapidRobert
I just called Ma & they are still available (pricey tho). they told me $4.25 ea which is full retail & I'm sure you could likely get em at a better rate
[Re: gts1]
#1634995
06/18/14 02:00 PM
06/18/14 02:00 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Also, a lot of times when installing anything that uses a soft copper or dead soft aluminum washer, I tighten and loosen and tighten and loosen the fitting at least a half dozen times to get them to bed together. I've eliminated a lot of leaking fittings this way.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
