Baseline jetting suggestions? #1633958
06/15/14 12:18 PM
06/15/14 12:18 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Ordered 770 Ultra Street Avenger vac secondary carb. Might throw it on today. Car ran 11.20s at 119 with current 750 double pump worked by local carb shop to be a "race" carb. That's too fast for Sportsman class and too fast for no roll cage. Car is 95% street driven at this point, so hoping this new carb will be a little friendlier and possibly slow it down a bit. It's brand new in the box right now, and have no idea what jets are in it. Any suggestions for a safe front and rear jet to start with?
69 Cuda. 3500 lbs with driver.
418 stroker 10.3:1 comp (pump gas)
Fully CNC'd Eddy Heads from Hughes.
Ported Airgap intake.
248/252 .600/.610 solid cam
Holley 750 modded to flow 910 CFM
MSD E-Curve dist with 6-AL
TTI torque stepped headers w/ Ultra Flo mufflers
3:91 727 Tight 10" converter.
For what it's worth, a local car show had a portable dyno that seemed to think the car puts down 485 HP at the wheels and around 450 ft lbs at the wheels.
Re: Baseline jetting suggestions? [Re: OA5599] #1633959
06/15/14 01:57 PM
06/15/14 01:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
send it back and get 1 of these
http://www.etgenie.com/
Re: Baseline jetting suggestions? [Re: Quicktree] #1633960
06/15/14 02:34 PM
06/15/14 02:34 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
I have 90 days to return it if I don't like it. I like the ET Genie, but I don't have the clearance to run it. The new carb has a choke and vac secondaries. I have time to give it a chance. Most people running the carb on the street seem to love it. I'll be keeping my 750 DP in case this new carb doesn't work out. But right now, the DP is most happy at wide open throttle. The shop that built the carb said it was built with best ET in mind, and not street duty.
Re: Baseline jetting suggestions? [Re: OA5599] #1633961
06/15/14 02:54 PM
06/15/14 02:54 PM
Az
Crizila Offline
Crizila  Offline
Az
Just run it out of the box and see how it does.
Fastest 300
Re: Baseline jetting suggestions? [Re: OA5599] #1633962
06/15/14 03:07 PM
06/15/14 03:07 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
A couple of things come to mind here;
First, if you like the ETGenie, why not just mill the 1" off the intake for the clearance that you need?
And before you make any changes to the new carb, you should run it and get some readings with a wide band. Otherwise you are just guessing as to what (if anything) needs attention and by how much.
Master, again and still
Re: Baseline jetting suggestions? [Re: DaveRS23] #1633963
06/15/14 03:21 PM
06/15/14 03:21 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
I like the idea of the ET Genie, but I don't need it. I simply don't race enough to justify one. The car is driven on the street more and more as years go by, rather than raced. I don't have a wide band on it. Just curious if anyone had suggestions on ball park jet sizes for baseline, and it can be tuned from there. Thanks for the responses.
Re: Baseline jetting suggestions? [Re: OA5599] #1633964
06/15/14 03:55 PM
06/15/14 03:55 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Stock jetting IS a good baseline. Go from there.
Re: Baseline jetting suggestions? [Re: Hot 340] #1633965
06/15/14 05:36 PM
06/15/14 05:36 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Start there.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Baseline jetting suggestions? [Re: joedust451] #1633966
06/15/14 05:46 PM
06/15/14 05:46 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
I have a fast wideband if you want to weld in a bung. Your welcome to use it.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
