What old mopar are you improving the suspension on? #1633019
06/13/14 07:07 AM
06/13/14 07:07 AM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
Been slowly collecting parts to improve the ride on my 70' Barracuda, hoping to get my last bit of parts in the next month. Been reading alot of posts on here and was wondering what cars/trucks are you guys building up and what mods are being done to them?
Re: What old mopar are you improving the suspension on? [Re: migsBIG] #1633020
06/13/14 11:48 AM
06/13/14 11:48 AM
NY NY
3
340duster340 Offline
NY NY
66 dart: firm feel bars front and back, FFI UCAs, new 6- leaf springs, 11.75 disc conversion, 8.75 rear, LBP, frame connectors. 318/auto for now, but would like to upgrade to 360 4 speed one day. should be a basic driver.
current status: front end all apart and working on putting it back together.
Re: What old mopar are you improving the suspension on? [Re: migsBIG] #1633021
06/13/14 11:51 AM
06/13/14 11:51 AM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
I have a 1970 Dart with 5.7 Hemi, Hotchkis rear suspension, E-Body rear sway bar, HemiDenny K-Frame, Addco 1" front sway bar, QA1 front coilovers, subframe connectors, 11" 4 wheel drilled/slotted disc brakes, 4.10 gears with carbon fiber clutches, 17x7" front wheels, 18x8" rear wheels.
Here is a link to my build:
http://www.forabodiesonly.com/mopar/showthread.php?t=226170
Re: What old mopar are you improving the suspension on? [Re: jrlegacy23] #1633022
06/13/14 12:38 PM
06/13/14 12:38 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Big brakes, big T-bars, big sway bars.
Sheldon
Re: What old mopar are you improving the suspension on? [Re: migsBIG] #1633023
06/13/14 05:09 PM
06/13/14 05:09 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
1972 Imperial.
As for the rest of it, let's not go there.
- Stu Harmon
Re: What old mopar are you improving the suspension on? [Re: feets] #1633024
06/13/14 07:07 PM
06/13/14 07:07 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Not working much on the suspension these days.
oth, I'll be swapping gears from 3.91 to 3.55:1 and be installing shorty headers and a 4bbl-intake on my daily 318 Dart soon.
Re: What old mopar are you improving the suspension on? [Re: BigBlockMopar] #1633025
06/13/14 11:45 PM
06/13/14 11:45 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
1.06 FF t-bars, 340 Duster leaf springs
FF adjustable struts and tie rod ends
Magnumforce non-adjustable tubular a-arms
poly bushings everywhere
welded and reinforced 340 K-frame
welded in Mopar frame connectors
KYB shocks
first gen Viper calipers on 11.75 rotors, EBC red pads
B-body rear with stock 11" drums, carbon metallic shoes
It's current setup has been on the car for a few seasons now and there are quite a few changes I would like to make, but it all costs $$$ and I'm having too much fun hammering on it. -pauly
Re: What old mopar are you improving the suspension on? [Re: pauly v.100] #1633026
06/13/14 11:51 PM
06/13/14 11:51 PM
Speedway In.
I
IndyDave Offline
IndyDave  Offline
I
Speedway In.
1979 Aspen
Replacing everything under it with a chassis from a Busch Grand National North car. The chassis is a Laughlin short track front steer and came as a roller minus brake calipers but with a freshened Richmond quick change.
Dave Dusterberg
1979 Aspen R/T (soon to be #19 CAM/T)
2002 Ram 1500 SLT
2005 Magnum R/T
2005 Mustang GT SCCA CAM/C #19
Re: What old mopar are you improving the suspension on? [Re: migsBIG] #1633027
06/14/14 01:44 AM
06/14/14 01:44 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I'll be removing all the drum brake stuff on my 8 3/4 this weekend and giving my friend a call to see if he can help me rebuild it. Going with all new bearings and seals, powder coated case, 3.55 gears, and an Eaton TrueTrac. I'll also be placing an order with Dr. Diff later this summer for some 13" Brembo discs up front and 11.7" Cobra brakes in the rear. On top of that, I already have my Hotchkis TVS in the garage with 1.06" T-bars and subframe connectors awaiting to go on the Dart. And lastly, I'm going to be getting some 2-piece 18" wheels set to my backspacing. I'm going to try to fit a 275/35/18 all the way around. If I have some extra time and money, I may do an engine swap for a 360. I know it's going to be a lot of money, but I don't care because it's my car. Hopefully, I can finish this all by late September (or to Fall Fling) with the help of friends and moparts.
The GT on the Dart is going to start for something new, "Gran Turismo." I know it's cheesy.
Re: What old mopar are you improving the suspension on? [Re: migsBIG] #1633028
06/14/14 02:47 PM
06/14/14 02:47 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Just getting started. So far front brakes are Dr Diff "Stage 4" and I have done a little fender trimming. Brought car home from paint today.
https://board.moparts.org/ubbthreads/show...e=3#Post8094659
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: What old mopar are you improving the suspension on? [Re: 68cuda440] #1633029
06/15/14 01:50 AM
06/15/14 01:50 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Looks like alot of a-body guys are fixing up their rides. I'm thinking of a complete suspension revamp, including aftermarket k-member, big Wilwoods, rack/pinion and welding in some chassis bracing to keep it a little tight. I have Magnum Force tubular adjustable control arms, subframe connector and Hotchkis rear leaf springs, but might upgreade to indecent rear later on.
Re: What old mopar are you improving the suspension on? [Re: migsBIG] #1633030
06/15/14 02:01 PM
06/15/14 02:01 PM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
71 Barracuda convertible, AlterKtion front and Street lynx rear with 6 piston 13" brakes front and rear
Re: What old mopar are you improving the suspension on? [Re: migsBIG] #1633031
06/15/14 07:53 PM
06/15/14 07:53 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I'm going to update my 65 Coronet. I already have for it: 500" aluminum Indy lowdeck wedge w/AEM EFI 664hp 651tq, fresh Pro Trans 727 w/manual valve body, custom Continental converter, GV o/d unit, everything to be had from FFI minus the k-frame, 70 k-frame so I can have through the frame sway bar/double shear mounted idler plus move the engine back 1 1/2", Strange S60 w/3.73's, Dr. Diff 4 whl disc, new tank[ to be modified for efi pump], frame connectors/torque boxes/safe t caps from ART, Sebring conv seats so I have shoulder harness. To be gathered up: Ron Francis wiring, SD Concepts serp belt system, wheels & tires, fuel plumbing, swap out existing HVAC unit for modern unit and re-route plumbing. I'm sure there will be more when I get into it.
Carl Kessel
Re: What old mopar are you improving the suspension on? [Re: migsBIG] #1633032
06/15/14 07:58 PM
06/15/14 07:58 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Picture of car
Carl Kessel
Re: What old mopar are you improving the suspension on? [Re: Chally426] #1633033
06/15/14 08:07 PM
06/15/14 08:07 PM
Battle Ground, Washington
Rapom65 Offline
Rapom65  Offline
'74 Duster. Front: Firm Feel 1.12 TB, Fox/Hotchkis non adj shocks, Hellwig 1.25" hollow sway bar, Dillinger chomemoly adj strut bars, Moog offset UCA bushings, Proforge solid aluminum tie rod adjusters, 11.75 B body disks & calipers, LCAs plated, Firm Feel Stage III PS rebuild, lower radiator cross member, sub frame connectors. Rear: home built HD version of a RMS Street Lynx poly bushed 4 link, Strange coilovers w/ QA1 150lb springs, 10 x 2.5 drum brakes.
Re: What old mopar are you improving the suspension on? [Re: migsBIG] #1633034
06/15/14 08:17 PM
06/15/14 08:17 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Another shot of car
Carl Kessel
Re: What old mopar are you improving the suspension on? [Re: CKessel] #1633035
06/16/14 04:42 AM
06/16/14 04:42 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I thought this was what the first post "suspension modification" was for??!
Re: What old mopar are you improving the suspension on? [Re: dangina] #1633036
06/16/14 05:23 AM
06/16/14 05:23 AM
The Netherlands
The Netherlands
Sticky topics that are up there too long tend to become invisible and get overlooked.
Besides, I think this topic was not ment for indept and detailed project-coverage from everyone but just a short general update what everyone is doing these days on their cars.
Does anyone update his post in the Modification Register-topic at all?
Edit:
Just noticed a topic's EDIT-function disappears after some time, so any updates would have to be done as a new reply on the Modification-topic.
Makes me wonder how useful an un-editable topic is as a 'Modification Register'...
Re: What old mopar are you improving the suspension on? [Re: BigBlockMopar] #1633037
06/16/14 12:46 PM
06/16/14 12:46 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
1977 Volare Road Runner. Replacing the entire front k-frame with a modified aftermarket kit for installing Gen I Dakota IFS parts into a 56 Ford F100. Tricky, but it's a good fit. Still working it.
Greg
Re: What old mopar are you improving the suspension on? [Re: BigBlockMopar] #1633038
06/16/14 01:38 PM
06/16/14 01:38 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Edit:
Yes, edit function on Moparts only lasts a certain period of time.
IIRC, I've had to add a second post.
so you go just copy what you wrote before and make changes. Maybe the post should have a place on top that says. As of this date: ________
