67 Coronet Auto trans.(Console) shifter button problem #1632501
06/12/14 01:42 PM
06/12/14 01:42 PM
Wisconsin
FFwithRT Offline OP
FFwithRT  Offline OP
Wisconsin
I can't seem to get my transmission button to allow me to shift into park. Is it just a simple fix? Thanks, Greg
Re: 67 Coronet Auto trans.(Console) shifter button problem [Re: FFwithRT] #1632502
06/12/14 01:43 PM
06/12/14 01:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A I think you can adjust it by screwing it up or down.
Re: 67 Coronet Auto trans.(Console) shifter button problem [Re: stumpy] #1632503
06/12/14 02:34 PM
06/12/14 02:34 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Yup,loosen set screw and turn the knob. Center button will therad on&off cable at the same time. Don't twist it down too tight or you can break the plastic center button pretty easily.damhik.
Re: 67 Coronet Auto trans.(Console) shifter button problem [Re: 67_Satellite] #1632504
06/12/14 10:42 PM
06/12/14 10:42 PM
Wisconsin
FFwithRT Offline OP
FFwithRT  Offline OP
Wisconsin
Thanks guys !
