Mopar Viscous fan. Where to buy? #1632230
06/11/14 07:56 PM
06/11/14 07:56 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I ordered a mopar viscous fan package P4120758 from summit racing about two months ago and it is still on back order. Every other place I can think of is out of stock too. Does anyone know where I can buy one? Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Mopar Viscous fan. Where to buy? [Re: 73cuda340] #1632231
06/11/14 08:03 PM
06/11/14 08:03 PM
IN
GTX4spd Offline
GTX4spd  Offline
IN
Don't know if they still carry 'em, but a few years back I got one from Advance Auto that was identical, even the part #, to my original, if originality is what you're after. Confess that I'm not familiar with the MoPar unit.
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: Mopar Viscous fan. Where to buy? [Re: 73cuda340] #1632232
06/11/14 08:08 PM
06/11/14 08:08 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I would cancel the order and look for the original fan then see what size clutch will fit, a good many guys who have ordered the mopar unit could not use the clutch because it was to long.
Re: Mopar Viscous fan. Where to buy? [Re: GTX4spd] #1632233
06/11/14 08:09 PM
06/11/14 08:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I "pieced" mine together on e-bay. I got the jag clutch (wish it was longer) and a used 5 blade viscous fan for under $60 (for both). Works just fine. We'll see if it's an improvement at the track at some point.
Coming soon!!!!
Re: Mopar Viscous fan. Where to buy? [Re: 73cuda340] #1632234
06/12/14 09:57 AM
06/12/14 09:57 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I just took a refresher course on the subject. I had totally forgot about this. If anybody's interested:
https://board.moparts.org/ubbthreads/show...amp;Search=true
Re: Mopar Viscous fan. Where to buy? [Re: Commando1] #1632235
06/12/14 11:03 AM
06/12/14 11:03 AM
Andrewh Offline
Andrewh  Offline
Just a side note.
if you have to replace the clutch, replace the water pump at the same time.
a damaged clutch can cause the wp to die sooner than you might think.
lost a rad because of that. just cheap insurance.
Re: Mopar Viscous fan. Where to buy? [Re: Andrewh] #1632236
06/12/14 12:50 PM
06/12/14 12:50 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
If looks are not an issue, just grab one off an 80's Ram somewhere.
Usually free or $10 from a wrecker.
Mo' Farts
Moderated by "tbagger".
Re: Mopar Viscous fan. Where to buy? [Re: Grizzly] #1632237
06/12/14 01:58 PM
06/12/14 01:58 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
There is a new one in IIRC parts ad here.Rocky
Chrysler Firepower
Re: Mopar Viscous fan. Where to buy? [Re: therocks] #1632238
06/12/14 04:06 PM
06/12/14 04:06 PM
dogdays Offline
dogdays  Offline
That mid-80s Fifth Avenue had one stock. You know, the maroon or dark blue Fifth sitting over in the corner of the PnP yard?
R.
Re: Mopar Viscous fan. Where to buy? [Re: dogdays] #1632239
06/12/14 07:10 PM
06/12/14 07:10 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yup, 80's 5th Aves and Rams had 'em stock. Some later Rams with Magnums may look similar, but their water pumps rotate opposite so stay away from them.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Mopar Viscous fan. Where to buy? [Re: GO_Fish] #1632240
06/12/14 07:16 PM
06/12/14 07:16 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I have a brand new set-up still in the box. Pm if interested. They have been back ordered for awhile now..
Re: Mopar Viscous fan. Where to buy? [Re: QuickBpBp] #1632241
07/02/14 09:48 PM
07/02/14 09:48 PM
clarks summit pa
clarks summit pa
I found some. www.moparproshop.com. They said they had four left in stock.
Re: Mopar Viscous fan. Where to buy? [Re: 73cuda340] #1632242
07/02/14 11:15 PM
07/02/14 11:15 PM
IN
ahy Offline
ahy  Offline
IN
I got mine from Mancini... out of stock now. They have the clutch only but $$.
To piece it together, suggest a JY fan. I understand later 70's used the 5 blade fan. That plus a standard duty thermal fan clutch from NAPA would be close.
Re: Mopar Viscous fan. Where to buy? [Re: ahy] #1632243
07/04/14 09:40 PM
07/04/14 09:40 PM
pasadena,md
red 69 runner Offline
pasadena,md
I got my 7 blade fan from http://www.tonysparts.com/.he sells the repopped clutch just like the originals,$200.00 for the clutch and $145 for the fan blade used.
Re: Mopar Viscous fan. Where to buy? [Re: red 69 runner] #1632244
07/06/14 06:49 PM
07/06/14 06:49 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
after have bought several clutches, From hayden to MP, and having AC ( then 7 blades fan ), got from Advance autoparts IMPERIAL Brand HD... which even seems to be made by Hayden, works WAY BETTER and same priced ( or cheaper )
Re: Mopar Viscous fan. Where to buy? [Re: NachoRT74] #1632245
07/06/14 06:59 PM
07/06/14 06:59 PM
BDW Online content
BDW  Online Content
Got a PN for that?
Re: Mopar Viscous fan. Where to buy? [Re: BDW] #1632246
07/07/14 11:40 AM
07/07/14 11:40 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
let's see if the link works:
http://shop.advanceautoparts.com/c3/radi...IdSearch=166788
should show all Imperial units from non thermal to heavy duty.
In fact Imperial seems to be the only Advance offers, because on search I didn't specified any brand.
made the search to my 74 Charger with 400. Got the Heavy Duty due the AC setup.
MP unit is not HD, just Thermal.
Re: Mopar Viscous fan. Where to buy? [Re: NachoRT74] #1632247
07/09/14 08:12 PM
07/09/14 08:12 PM
clarks summit pa
clarks summit pa
I just received my fan. I thought the viscous fan kits were a five blade fan, however I received a six blade fan. Also there is a sticker on the one fan blade that states that the maximum rpm for the fan is 4,000 rpm. Is this right?
Re: Mopar Viscous fan. Where to buy? [Re: 73cuda340] #1632248
07/09/14 08:16 PM
07/09/14 08:16 PM
MD
floyd Offline
floyd  Offline
MD
I just bought one from Galena Chrysler Jeep in SC. Website shows this:
http://www.moparproshop.com/inc/sdetail/1889
The clutch unit in the pic is pretty nice and the back looks very similar to an original viscous unit (front is totally different of course)
Re: Mopar Viscous fan. Where to buy? [Re: floyd] #1632249
07/09/14 08:17 PM
07/09/14 08:17 PM
MD
floyd Offline
floyd  Offline
MD
I got this piece of crap
