Speedometer Cable #1631304
06/09/14 11:31 PM
06/09/14 11:31 PM
Spartanburg SC
MoparDan Offline OP
MoparDan  Offline OP
Spartanburg SC
over a year ago, my (new when I restored; 1500 miles ago) speedo cable started rattling like crazy while driving.
I unplugged it from the back of speedometer, and then pulled the inner cable from the housing.
I want to fix and re-install.
** Does it need some grease coating on it as I reinstall?
I believe the rattle was the cable smacking/rattling against the sides of the cable housing..?
Will a little bearing grease fix that. Never had a problem, then suddenly noise. The (newer) cable was dry when I pulled it a year ago.
Thanks in advance!!
1971 road runner
Re: Speedometer Cable [Re: MoparDan] #1631305
06/09/14 11:51 PM
06/09/14 11:51 PM
Yes you need grease. I bought a cut to fit inner cable and it came with a mini bubble pack of green grease. I wouldn't be afraid to use wheel bearing grease unless someone says that that is a bad idea
Re: Speedometer Cable [Re: RapidRobert] #1631306
06/09/14 11:53 PM
06/09/14 11:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Vaseline or white lube.
Re: Speedometer Cable [Re: stumpy] #1631307
06/10/14 12:03 AM
06/10/14 12:03 AM
Spartanburg SC
MoparDan Offline OP
MoparDan  Offline OP
Spartanburg SC
Thanks guys, thats what I thought. When I bought the cable from Dodge dealer, came with no grease, just together in plastic.
Stumpy: would'nt white grease (and vasoline) just liquefy with minimal heat; while bearing grease would stay solid?
Thanks!
Re: Speedometer Cable [Re: MoparDan] #1631308
06/10/14 12:22 AM
06/10/14 12:22 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You don't want it solid packed. It doesn't run in grease. You just want a very light coating on the cable core. Shouldn't be any heat inside the cable housing normally.
Re: Speedometer Cable [Re: stumpy] #1631309
06/10/14 12:56 PM
06/10/14 12:56 PM
dogdays Offline
dogdays  Offline
A cable is long compared to the end that drives it. Any #2 grease is too heavy. Use it and you run the risk of shearing the end off.
Just a light coating of Vaseline would work well. For a different scent inside the car, use a light coating of Vicks Vaporub.
R.
Re: Speedometer Cable [Re: dogdays] #1631310
06/10/14 02:39 PM
06/10/14 02:39 PM
WV,USA
W
wvmarv Offline
wvmarv  Offline
W
WV,USA
Yea, you'll have a well lubed cable and clear sinuses. Lol
Re: Speedometer Cable [Re: MoparDan] #1631311
06/10/14 04:06 PM
06/10/14 04:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I used white lithium grease on my speedo cable.
- Stu Harmon
Re: Speedometer Cable [Re: MoparDan] #1631312
06/10/14 05:40 PM
06/10/14 05:40 PM
NC
1970A66 Offline
1970A66  Offline
NC
I've read this is good. And it comes with an applicator.......
Re: Speedometer Cable [Re: 1970A66] #1631313
06/11/14 02:28 PM
06/11/14 02:28 PM
dogdays Offline
dogdays  Offline
Multi-purpose!
R.
