High flow CNC BB Victors #1630928
06/09/14 03:34 AM
06/09/14 03:34 AM
IL
E
EchoSixMike Offline OP
E
IL
http://www.hughesengines.com/Index/themaxwedgeisdead.php
Wonder what gaskets this uses? 355cc ports. Flows almost like a B-1. I have a set of Victors and a 4.5" crank cooling in my basement, I might have to send the heads to Hughes and see how they turn out. S/F....Ken M
Re: High flow CNC BB Victors [Re: EchoSixMike] #1630929
06/09/14 09:29 AM
06/09/14 09:29 AM
Better if sent to Todd at Marsh Performance a sponspor here he made 1000HP with them this year on a very stingy dyno--call him first--you won't regret it. Moparts Connection/ Todd Marsh
Victors are something he has figured out a long time ago--Todds porter has won Daytona 500 several times--he Knows heads period!
Re: High flow CNC BB Victors [Re: ] #1630930
06/09/14 09:41 AM
06/09/14 09:41 AM
The Great White North
RAMM Offline
RAMM  Offline
The flow @ .400" has me very suspicious. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: High flow CNC BB Victors [Re: RAMM] #1630931
06/09/14 10:58 AM
06/09/14 10:58 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
If that's "for real" that's very good
IIRC my Chapman 285's flowed around:
285 @.400
335 @.500
361 @.600
381 @.750-.800
WIZE
In Car:
Re: High flow CNC BB Victors [Re: ] #1630932
06/16/14 02:14 PM
06/16/14 02:14 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
We are also a sponsor here at Moparts and have been for many years. Our flow numbers are real. These heads work really, really well. The intake ports are the standard Max Wedge dimensions.
Re: High flow CNC BB Victors [Re: Hughes] #1630933
06/16/14 02:43 PM
06/16/14 02:43 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
What is the deal with 4.400 bore then? Mine is 4.500
From your website: " Hughes Engines is now offering Edelbrock VictorŽ heads with Monster Max Wedge intake ports. These C.N.C. ports will outflow any other head on the market, without relocated valves! And, that's not all. How does a "Monster" 355cc port volume sound? If you are running a 4.400" or smaller bore, large cubic inch engine that is 500+ cubic inches, or a high RPM 440 and you need more air, then you need "Monster Max Wedge Heads". "
Re: High flow CNC BB Victors [Re: Streetwize] #1630934
06/16/14 02:46 PM
06/16/14 02:46 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
285 @.400
335 @.500
361 @.600
381 @.750-.800
What size intake valves were they on those heads?
Re: High flow CNC BB Victors [Re: Airwoofer] #1630935
06/16/14 04:38 PM
06/16/14 04:38 PM
AndyF Offline
AndyF  Offline
The 4.400 or smaller bore size is probably a typo. I'm sure that Hughes ment to say 4.400 bore size or larger
Re: High flow CNC BB Victors [Re: AndyF] #1630936
06/16/14 06:48 PM
06/16/14 06:48 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
The MCH version, big valves, big ports.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: High flow CNC BB Victors [Re: d7cook] #1630937
06/16/14 06:59 PM
06/16/14 06:59 PM
ill
dennismopar73 Offline
ill
Issue is
How to keep intake gasket from sucking thru
Re: High flow CNC BB Victors [Re: dennismopar73] #1630938
06/16/14 07:17 PM
06/16/14 07:17 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Issue is
MCH did a set of Buick heads for me that were that thin and I never had a problem.
