Re: Disappointment at the dyno
[Re: an8sec70cuda]
#1628840
06/05/14 03:53 PM
06/05/14 03:53 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Don't be tempted by the big B1 intake you mentioned in the classifieds...it will KILL your lowend torque.
Besides that it's not going to even bolt to his 906's
[Re: 70Drop]
#1628844
06/05/14 06:56 PM
06/05/14 06:56 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I'm running 4:10 gears and a 30-inch 10.5 wide slick
I have not checked fuel pressure during a full run, just for shorter tests on the street (I do not have a fuel pressure gauge in the cockpit.
After my earlier post, I looked at the B1 and realized it was Max Wedge ports, so I wouldn't use that.
Once I get this combo dialed in and my 60-foot down, I'm thinking maybe a head change would be the next step for the engine. I'd also lose a bunch of weight off the front of the car, which would be nice. Would you agree the heads are the best next step? Since it's a street/strip car, I would prefer not to go crazy-big on the cam.
I have looked into the EZ heads a bit. They seem like a good way to go, although a little pricey. Even more with CNC porting. I guess they flow like 340ish with CNC? That's probably more than I need.
You can always slow it down but it is impossible to speed it up if you don’t have it. I always error on the side of making a little more power, that way you got it if you need to use it.
[Re: ]
#1628845
06/05/14 07:27 PM
06/05/14 07:27 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Anyone that works with Mopars on the dyno knows that 35 is not enough timing--that is at the point where a few more degrees means big leaps in HP usually--many like around 41 or so in my experience--now I know it all comes down to combustion chamber--piston top etc but 35 will not get it when seeking best power numbers in most cases
Now you did it. Don't you know that 36 to 38° is the only right timing for a BB Mopar. I read it so myself right here on this forum and a magazine.
[Re: 70Drop]
#1628846
06/05/14 07:51 PM
06/05/14 07:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
To be honest I dont think your heads are the choke.. you need a 1050 for the cubes.. but thats for a race car... I dont know if you want to play with the fuel on the street
[Re: MR_P_BODY]
#1628847
06/05/14 08:00 PM
06/05/14 08:00 PM
Posts: 223 California
70Drop
California
Hmmm. Maybe a six-pack?
[Re: 70Drop]
#1628851
06/05/14 10:42 PM
06/05/14 10:42 PM
MR_P_BODY
Any engine I have thrown more carb at helped in power but lets look at the math.. what did a stock 440 come with for carb.. 850... then do the percentage of yours.. thats the minimum ... or if you want you can put a vac gauge on the intake and see what you have.. but I have found that the sooner that gauge gets to zero the better.... IF it does... I havent ever run a 6 pac but I have run tunnel rams but I had bad carbs on them... I only run a DP now days
[Re: Thumperdart]
#1628852
06/06/14 12:44 AM
06/06/14 12:44 AM
Posts: 2,512 PA
moparacer
PA
Better heads and then a bigger cam...
You can hang a bunch of mismatched parts around a good set of heads and most of the time the engine will still run strong.
You can hang a bunch of good parts around a bad set of heads and you will end up with a slug.
A good set of heads that will feed the cid at your RPM range is everything.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
