Page 3 of 3 1 2 3
Re: Disappointment at the dyno [Re: an8sec70cuda] #1628840
06/05/14 03:53 PM
06/05/14 03:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Don't be tempted by the big B1 intake you mentioned in the classifieds...it will KILL your lowend torque.
Besides that it's not going to even bolt to his 906's
Re: Disappointment at the dyno [Re: JohnRR] #1628841
06/05/14 03:58 PM
06/05/14 03:58 PM
dogdays Offline
dogdays  Offline
IMHO the heads, while they may represent a lot of money, are the limiting factor. And the fact that we have no flowbench numbers leaves me really questioning them.
A decent flowing set of aluminum heads, with the additional compression ratio that they can accommodate, would make quite a difference even with the cam that's in it now.
Where'd you guys go with this? I'm thinking Indy EZs. I'm interested in some educated opinions.
R.
Re: Disappointment at the dyno [Re: dogdays] #1628842
06/05/14 05:17 PM
06/05/14 05:17 PM
California
70Drop Offline OP
70Drop  Offline OP
California
I'm running 4:10 gears and a 30-inch 10.5 wide slick
I have not checked fuel pressure during a full run, just for shorter tests on the street (I do not have a fuel pressure gauge in the cockpit.
After my earlier post, I looked at the B1 and realized it was Max Wedge ports, so I wouldn't use that.
Once I get this combo dialed in and my 60-foot down, I'm thinking maybe a head change would be the next step for the engine. I'd also lose a bunch of weight off the front of the car, which would be nice. Would you agree the heads are the best next step? Since it's a street/strip car, I would prefer not to go crazy-big on the cam.
I have looked into the EZ heads a bit. They seem like a good way to go, although a little pricey. Even more with CNC porting. I guess they flow like 340ish with CNC? That's probably more than I need.
Re: Disappointment at the dyno [Re: 70Drop] #1628843
06/05/14 06:36 PM
06/05/14 06:36 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I am running a 440/505 ported stage iv head with 11.0 compression and solid cam with a tunnel ram.
My b body is 4065 pounds in street trim (the way I race it) and it has gone on 11:21 @ 120mph tippy toeing off the line with street tires. You need to sort your car out, you should be in the high ten’s.
Re: Disappointment at the dyno [Re: 70Drop] #1628844
06/05/14 06:56 PM
06/05/14 06:56 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
You can always slow it down but it is impossible to speed it up if you don’t have it. I always error on the side of making a little more power, that way you got it if you need to use it.
Re: Disappointment at the dyno [Re: ] #1628845
06/05/14 07:27 PM
06/05/14 07:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Anyone that works with Mopars on the dyno knows that 35 is not enough timing--that is at the point where a few more degrees means big leaps in HP usually--many like around 41 or so in my experience--now I know it all comes down to combustion chamber--piston top etc but 35 will not get it when seeking best power numbers in most cases
Now you did it. Don't you know that 36 to 38° is the only right timing for a BB Mopar. I read it so myself right here on this forum and a magazine.
Re: Disappointment at the dyno [Re: 70Drop] #1628846
06/05/14 07:51 PM
06/05/14 07:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To be honest I dont think your heads are the choke..
you need a 1050 for the cubes.. but thats for a race
car... I dont know if you want to play with the fuel
on the street
Re: Disappointment at the dyno [Re: MR_P_BODY] #1628847
06/05/14 08:00 PM
06/05/14 08:00 PM
California
70Drop Offline OP
70Drop  Offline OP
California
on the street
Hmmm. Maybe a six-pack?
Re: Disappointment at the dyno [Re: 70Drop] #1628848
06/05/14 08:08 PM
06/05/14 08:08 PM
Carson City, Nevada
Carson City, Nevada
NOPE!
6 packs will not work as well as a single four plus the your limited on an intake manifold.
Re: Disappointment at the dyno [Re: Biginchmopar] #1628849
06/05/14 09:42 PM
06/05/14 09:42 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
How about a tunnel ram?
Re: Disappointment at the dyno [Re: 70Drop] #1628850
06/05/14 10:31 PM
06/05/14 10:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The engine is making 500+ HP at the crank, your just loosing alot through accessories, and drivetrain.
The time slip looks good compared to mine. I am running right at 120 MPH too, but in the 12.6 to 12.7 range. I haven't ran since I installed the spool in the rear axle, but I hope it helps my traction issues.
Re: Disappointment at the dyno [Re: 70Drop] #1628851
06/05/14 10:42 PM
06/05/14 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
on the street
Any engine I have thrown more carb at helped in power
but lets look at the math.. what did a stock 440
come with for carb.. 850... then do the percentage
of yours.. thats the minimum ... or if you want you
can put a vac gauge on the intake and see what you
have.. but I have found that the sooner that gauge
gets to zero the better.... IF it does... I havent
ever run a 6 pac but I have run tunnel rams but I
had bad carbs on them... I only run a DP now days
Re: Disappointment at the dyno [Re: Thumperdart] #1628852
06/06/14 12:44 AM
06/06/14 12:44 AM
PA
moparacer Offline
moparacer  Offline
PA
Better heads and then a bigger cam...
You can hang a bunch of mismatched parts around a good set of heads and most of the time the engine will still run strong.
You can hang a bunch of good parts around a bad set of heads and you will end up with a slug.
A good set of heads that will feed the cid at your RPM range is everything.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Page 3 of 3 1 2 3
