Who's installed torsion bars on a rotisserie car? #1628786
06/04/14 07:34 PM
06/04/14 07:34 PM
California
BigDaddy440 Offline OP
California
So I'm a little stuck. My A12 is on my rotisserie and the front suspension, A arms etc, and hanging loose without the T-bars in. The Torsion bars can be installed so that if the car is right side up, the front suspension is under load (from the bars) and pushed way down toward the ground. They can also be installed where the front suspension is not maxed out toward the ground, but I don't know which way is correct.
This scenario would be the same if you were installing the T-Bars on a car on Jack Stands.
I guess the best question would be: When T-Bars are installed correctly, and the car is raised off the ground with zero load, how far down / what angle should the A-Arms be positioned?
I also could use some advice / direction on how to adjust the bolt that adjusts the ride height.
Any help would be appreciated. Thanks.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Who's installed torsion bars on a rotisserie car? [Re: BigDaddy440] #1628787
06/05/14 12:58 AM
06/05/14 12:58 AM
California
California
Maybe pictures will help.
Does this look right, or is the suspension being forced too far down?
Here is the passenger side. Torsion Bar is in, and A-Arms are under load of the T-Bar. Obviously when the weight of the car sits on the suspension the the Torsion bar will twist and the A-Arms will move north.
I need to know if this is correct or do I need to pull the T-Bar back out and move the LCA "up" and reinstall the torsion bar so that the suspension is not so far down.
If this sounds all wrong, I'm sorry..this is the first time I've rebuilt a mopar suspension system.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Who's installed torsion bars on a rotisserie car? [Re: BigDaddy440] #1628788
06/05/14 01:09 AM
06/05/14 01:09 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
FYI
Your spindle bolts are installed backwards.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Who's installed torsion bars on a rotisserie car? [Re: hemi71x] #1628789
06/05/14 01:14 AM
06/05/14 01:14 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The suspension should be at the bottom of its travel with the shocks free as well. The t-bars should slide in with very little effort.
Since there are only 6 flats on the bars, I doubt you could install them wrong.
Re: Who's installed torsion bars on a rotisserie car? [Re: hemi71x] #1628790
06/05/14 01:36 AM
06/05/14 01:36 AM
California
California
FYI
Thanks. Yeah, I wasn't sure...I'm still mocking up the disc brake conversion. I'll turn them around when I put it together for good.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Who's installed torsion bars on a rotisserie car? [Re: Stanton] #1628791
06/05/14 01:38 AM
06/05/14 01:38 AM
California
California
So with the shocks installed, all suspension should be hanging free, then install the torsion bars?
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Who's installed torsion bars on a rotisserie car? [Re: BigDaddy440] #1628792
06/05/14 04:57 AM
06/05/14 04:57 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
I'd disconect/remove the shocks and remove the bump stop for the UCA.
Re: Who's installed torsion bars on a rotisserie car? [Re: BigDaddy440] #1628793
06/05/14 10:09 AM
06/05/14 10:09 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You need to get a FSM, it will tell you everything you need to know.
Re: Who's installed torsion bars on a rotisserie car? [Re: 71birdJ68] #1628794
06/05/14 11:01 AM
06/05/14 11:01 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The shocks don't need to be installed but if they are they have to be disconnected or they'll raise the suspension enough that the bars won't slide in. Bump stops didn't interfere when I put mine in.
If you're restoring the car yourself a FSM sure would come in handy !!
Re: Who's installed torsion bars on a rotisserie car? [Re: nomore65BelvJim] #1628795
06/05/14 11:46 AM
06/05/14 11:46 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I'd disconnect/remove the shocks and remove the bump stop for the UCA.
Is the car still on the rotisserie?
How do you intend to install the engine/tranny?
Master, again and still
Re: Who's installed torsion bars on a rotisserie car? [Re: BigDaddy440] #1628796
06/05/14 12:24 PM
06/05/14 12:24 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
FYI
Oh, you would have found out soon enough when you went to button up the rest of the brakes..
Troy
Houston Mopar Connection Club
Re: Who's installed torsion bars on a rotisserie car? [Re: hemi68charger] #1628797
06/05/14 01:14 PM
06/05/14 01:14 PM
New State
kidmopar Offline
kidmopar  Offline
New State
Dan , Looks AWESOME !
Hopefully you'll have time to work on this summer ?
Kevin
Tracy , CA.
Re: Who's installed torsion bars on a rotisserie car? [Re: kidmopar] #1628798
06/06/14 08:11 PM
06/06/14 08:11 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would leave everything off the lca then hang them about seven to eight o-clock with adjusters out. They would be the last thing to be installed if mine. Like one said only six flats, hard to install wrong unless swaped side to side, L&R
Re: Who's installed torsion bars on a rotisserie car? [Re: cudaman1969] #1628799
06/06/14 09:25 PM
06/06/14 09:25 PM
Central Utah
Mopargnome Offline
Mopargnome  Offline
Central Utah
I cant help with your problem, but looking good!
