1969 "H" wheel color #1628340
06/03/14 11:41 PM
06/03/14 11:41 PM
Kentucky USA
RR6BBL1969 Offline OP
Kentucky USA
What do you guys say the right color is for the H wheels? Gloss black? or Semi gloss black?
I have seen them both ways on some very nice A 12's.
Re: 1969 "H" wheel color [Re: RR6BBL1969] #1628341
06/03/14 11:57 PM
06/03/14 11:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Gloss black IMO.....and in a year of driving them through all kinds of conditions like snow and grime the will be that nice semi-gloss some think they should be. So paint them high gloss and it's a win-win
Re: 1969 "H" wheel color [Re: A12] #1628342
06/04/14 12:01 AM
06/04/14 12:01 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
X2
Admiration For Multiple Carburetor Vehicles...
Re: 1969 "H" wheel color [Re: RR6BBL1969] #1628343
06/04/14 12:12 AM
06/04/14 12:12 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
On my 69 car with factory black wheels, the build sheet under wheel says "X9".
X9 was the 69 Black Velvet exterior body color which was a gloss. So X9 Black Velvet gloss should be correct, unless your build sheet says something else.
Re: 1969 "H" wheel color [Re: RR6BBL1969] #1628344
06/04/14 02:33 AM
06/04/14 02:33 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Regardless of what the paint was originally called, the wheels did not appear as "glossy" as the exterior of a black car.
Re: 1969 "H" wheel color [Re: DoctorDiff] #1628345
06/04/14 08:34 AM
06/04/14 08:34 AM
Kentucky USA
Kentucky USA
Okay. Gloss black it is. Thanks
Re: 1969 "H" wheel color [Re: DoctorDiff] #1628346
06/04/14 09:37 AM
06/04/14 09:37 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Take some polish to an original and see how bright of a luster you can get to come up. For sure not the high gloss available today.
Just my
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: 1969 "H" wheel color [Re: DoctorDiff] #1628347
06/04/14 11:50 AM
06/04/14 11:50 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
So when a car has "body color" wheels, when equipped with just hub caps, the wheels are not painted with the body color paint but with special lower gloss body color wheel paint at a special location in the plant's paint department? I would think it is more in the paint prep process and not the paint that would determine the final finish. I don't think much is done to the wheels other than to degrease them before they paint them? What primer was used for the wheels?
(Doc I'm actually agreeing with you on the finish because of the wheel prep before paint )
Re: 1969 "H" wheel color [Re: Big D A12] #1628348
06/04/14 11:54 AM
06/04/14 11:54 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Here is the inside of an original 5-14-69 H-wheel. I had the redline tire (never on the ground) removed two years ago. It looks pretty glossy to me
Re: 1969 "H" wheel color [Re: 70440+6bbl] #1628349
06/04/14 01:32 PM
06/04/14 01:32 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Looks semi-gloss to me.
Do you think that sheen would look acceptable on the car's sheetmetal?
Re: 1969 "H" wheel color [Re: DoctorDiff] #1628350
06/04/14 01:42 PM
06/04/14 01:42 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Doc IMO it's the prep not the paint that has more to do with the finish. I've seen "rattle-can" paint look better than $500 a gallon bodyshop paint when an item is properly prepped. How about these, my small h-wheels done with a little care and good prep and cheap paint......
Re: 1969 "H" wheel color [Re: A12] #1628351
06/04/14 01:44 PM
06/04/14 01:44 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
before prep
Re: 1969 "H" wheel color [Re: A12] #1628352
06/04/14 01:45 PM
06/04/14 01:45 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Once again, regardless of what the paint was originally called, black wheels do not APPEAR to be gloss black.
All BLACK wheels left the factory with a light coat applied directly over the raw steel.
As far as I know, BODY COLOR wheels (other than black) were treated to a second coat of matching paint over the black base coat. This base coat acted like sealer, resulting in a higher gloss finish.
Re: 1969 "H" wheel color [Re: DoctorDiff] #1628353
06/04/14 01:58 PM
06/04/14 01:58 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Wouldn't that mean that if you used X9 gloss body paint on a non-primered steel wheel the finish would end up closer to correct than painting it with semi-gloss
Re: 1969 "H" wheel color [Re: DoctorDiff] #1628354
06/04/14 02:42 PM
06/04/14 02:42 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
It's glossier in person, but I understand what you are saying.
Re: 1969 "H" wheel color [Re: 70440+6bbl] #1628355
06/04/14 02:44 PM
06/04/14 02:44 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Talk about deja vu! https://board.moparts.org/ubbthreads/show...e=0#Post7406447
Same people, same comments...
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 1969 "H" wheel color [Re: DPelletier] #1628356
06/04/14 02:56 PM
06/04/14 02:56 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
LOL
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 1969 "H" wheel color [Re: A12] #1628357
06/04/14 02:58 PM
06/04/14 02:58 PM
Texas
bogusracer Offline
bogusracer  Offline
Texas
I think there are a couple of items regarging the painting of wheels that most people don't understand:
1. Most if not all components that were painted in the factory were treated through a Phosphate System to clean the metal with Detergents and treat it with a phosphate coating to help inhibit rust. This process turns the metal from a bright shiny - "Raw" Steel appearance to a dull gray appearance. It also etches the metal for better paint adhesion. This is not what most of us hobbyists do when we paint parts at home. We generally prime then paint. However DuPont used to have a Product that you could treat bare steel with that would do essentially the same thing as the factory Phosphate Process. It would leave the metal dull gray and etch it for better paint adhesion.
2. The major reason you did not get the high gloss finish on the wheels was the fact that the paint was applied at a lower film build thickness and subsequently was not "Wet Out sufficiently" when sprayed to gloss up like the outer body was. This was due in part to the fact that they only got one coat of color paint, Compared to the bodies getting 2 or more coats applied wet on wet in the spray booths. The photos from the home sprayed wheels in a post above, where they used Rattle Can" paint is a great illustration of getting sufficient film thickness to get maximum gloss from the paint sprayed. You have to understand in most assembly plant applications back in the late 60's and through the 70's, those wheels were painted on a sub-assembly conveyor at the rate of about 60 jobs per hour, so as they went by they were either hand painted or had a stationary Automatic Spray application with enough paint sprayed to get color on them and be shiny, but they were not subject to the same appearance standards as the outer body of the car was. Subsequently they were not as glossy as the primed, sanded and prepped bodies were back then.
You can probably run a test at home yourself by spraying a bare metal panel with a light coat application and then spary another one with a couple of "Wet coat" applications. then take a look at the difference of the gloss when they are dry. My money is on the one with multiple wet coats having a much higher gloss that the single coat lower film build panel.
Hopefully this will shed some light on the reason the wheels did not shine or were not as glossy as the body was, even though they had the same paint used on both the body and wheels.
Bogusracer - 38 years and counting in Paint applications in an Auto Assembly Plant.
Re: 1969 "H" wheel color [Re: bogusracer] #1628358
06/04/14 03:19 PM
06/04/14 03:19 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
and as I said use gloss black X9 body paint and paint them like they would have been painted in 1969 and they will look somewhat glossy on the showroom then semi-gloss later....but the bottom line IMO they should be painted with the same percent shine (gloss) gloss black body paint first.
(Don't worry this has been going on for decades and will keep going on, wish they would have just put full wheel covers on the A12 or painted them body color like one of the protos )
Re: 1969 "H" wheel color [Re: A12] #1628359
06/04/14 03:21 PM
06/04/14 03:21 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, you will get the same comments from the same people if you ask the same people the same question.
Once again, yes, you will get a semi-gloss finish if you spray a light coat of gloss paint over bare steel.
