Re: next 2295 question... how much lift
[Re: big_wedge]
#1625110
05/26/14 04:10 AM
05/26/14 04:10 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
When I am back home from work I can send you my cam specs. I am running these pistons with a solid roller with .580 lift. No problems. The pistons already have a valve relief.
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: Cab_Burge]
#1625111
05/26/14 04:14 AM
05/26/14 04:14 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I have 2295f in my street car along with a set of big valve 906 heads. I run a 292@.050 with.635" lift and a 110* lsa solid crower cam with no issues.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: big_wedge]
#1625112
05/26/14 04:48 AM
05/26/14 04:48 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
It's the cam duration, LSA (overlap), and installed centerline, not advertised lift that matters because the valves are closest to hitting the piston in the overlap period, just before and after TDC.
I don't know which pistons those are, but I would check the thickness of the piston at the valve notch.
I was thinking of cutting the valve notches deeper in my KB ICON pistons, but the piston is only about 0.210" thick at the valve notch already.
[Re: big_wedge]
#1625114
05/26/14 08:55 AM
05/26/14 08:55 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Many factors come into play for piston to valve clearence. Valve size cam lift Cam advance advance or retard block deck height piston height If you have all your assembly information you can figure the clearence needed.
[Re: MRMOPAR622]
#1625116
05/26/14 01:14 PM
05/26/14 01:14 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
With a .543 you have plenty of room.I used to run these pistons(lighten)and the Speed Pro exact specs.Just make sure you have good rod bolts.
Guess that's how yall roll down in 'Bama?
OP take what was already stated above to the bank and CHECK IT YOURSELF. It's very easy to do.
It's the cam duration, LSA (overlap), and installed centerline, NOT ADVERTISED VALVE LIFT that matters because the valves are closest to hitting the piston in the overlap period, just before and after TDC.
Cab is also correct, opening rate is also a critical factor.
Other factors in which no two motors are alike: Deck height, chamber cc, head gasket choice, valve diameter. CHECK IT YOURSELF...
