Took the Charger to the track today.... First time! #1624660
05/25/14 04:15 AM
05/25/14 04:15 AM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
So I took my 68 Charger to the track today. This was not only the first time I have taken the Charger, but also the first time I have ever raced at the track.
I was on my street tires, car would not hook up at all, I had to ease it out off the line.
Anyhow, I didn't run all that well of an ET, but I think I am happy with the MPH. The car was fat at the top end beyond 4600 RPM. I kept taking fuel out of it, but by the end of the night I was still at 11.8 AFR.
Need to take more out.
Anyone want to analyze this for me?
Picture of car as raced.
Re: Took the Charger to the track today.... First time! [Re: redmist] #1624661
05/25/14 04:25 AM
05/25/14 04:25 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
With some sticky tires and getting that 60 ft down in the 1.8 area, I see solid mid 12`s.
Re: Took the Charger to the track today.... First time! [Re: SCATPK] #1624662
05/25/14 04:36 AM
05/25/14 04:36 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nice pass!
Re: Took the Charger to the track today.... First time! [Re: redmist] #1624663
05/25/14 08:17 AM
05/25/14 08:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Nice car
Re: Took the Charger to the track today.... First time! [Re: redmist] #1624664
05/25/14 12:17 PM
05/25/14 12:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Dial in the carb, get the 60`s down and you`re in the 12`s............NICE!
Re: Took the Charger to the track today.... First time! [Re: redmist] #1624665
05/25/14 01:02 PM
05/25/14 01:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I see you have a front sway bar... thats gonna hurt
your 60' times due to it not allowing the front lift
easy
Re: Took the Charger to the track today.... First time! [Re: MR_P_BODY] #1624666
05/25/14 01:22 PM
05/25/14 01:22 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
Awesome!
Next time I will drop the sway bar links.
No carb on this one, I was data logging, and slowly taking fuel out of my VE map. I was being ultra conservative so as not to lean it out, but didn't get enough out at the top end.
I don't have sub frame connectors in this car, so I think that is priority one before hitting the track again. I might invest in some drag radials down the road.
The car is built to be a street machine, but I would love to get it in the low 12's (Just Cuz)
My first pass, I was lined up with a pickup that had Drags, nasty sounding engine, He ran a 12.7, but at only 105 or so. Mid track I started to catch up to him, and man that was exciting! My reaction time on that run was a .700 Oops.
Re: Took the Charger to the track today.... First time! [Re: redmist] #1624667
05/25/14 04:57 PM
05/25/14 04:57 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Get a pair of 10in slicks and some skinnies up front and mount them on some nice light rims. You can simply swap from your street tires/rims when you're racing. Get a set of adjustable front shocks, lose the sway bar, work the tune with more laps and you'll meet your ET goal.
You can even shed some weight beyond the rims with stuff like a light battery and aluminum radiator, if you don't already have that stuff......without breaking the bank, or altering the appearance of the car.
Very nice car, by the way....
Re: Took the Charger to the track today.... First time! [Re: jim sciortino] #1624668
05/25/14 05:37 PM
05/25/14 05:37 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
It has a ton of aluminum in it.
I weighed it at the truck stop just before going to the track.
3/4 tank of gas, and me NOT in it, the car weighed 3620. i don't know what they normally weigh.
Re: Took the Charger to the track today.... First time! [Re: redmist] #1624669
05/25/14 09:43 PM
05/25/14 09:43 PM
Taylor, Michigan
1BadLiLCharger Offline
Taylor, Michigan
You already have low 12 mph, just get it to hook...
Re: Took the Charger to the track today.... First time! [Re: 1BadLiLCharger] #1624670
05/26/14 03:11 AM
05/26/14 03:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Very nice charger. With that 110 mph you have mid to low 12 second power. Get some hook and bring that 60 down and be happy. I ran 12.30's @ 110 mph years ago in my 383 Dart with just SS springs and G60 McCreary's. How about a rundown on the combo if you dont mind. And good luck next time at the track. Ron
Re: Took the Charger to the track today.... First time! [Re: 383man] #1624671
05/26/14 03:27 AM
05/26/14 03:27 AM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
Sure!
Its a basic .30 over 1967 440 block
SRP forged pistons at zero deck, K1 Rods, ARP 2000 bolts
Studs top and bottom, windage tray
Comp XS282S Camshaft, Crane Gold 1.5 rockers
Edelbrock RPM 84cc heads right out of the box
Intake is an Edelbrock Pro-Flo MPFI
2013 Ford GT-500 60lb hr injectors
Home built Megasquirt MS3X ECU Full sequential fuel/spark
Chevy D-585 Coils
92MM Throttle body
Trans is a copes built 727 with a billet front drum
11" PTC Converter
3.91 gears
Tires are Nitto NT-555. Rear is a 285 wide tire on 17" rims
I crossed the line right at 6000 RPM! I had my rev-limiter set at 6100, haha Might bump that out a bit.
Re: Took the Charger to the track today.... First time! [Re: redmist] #1624672
05/26/14 09:38 AM
05/26/14 09:38 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Good looking car.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Took the Charger to the track today.... First time! [Re: redmist] #1624673
05/26/14 10:03 AM
05/26/14 10:03 AM
johnmilner Offline
johnmilner  Offline
13.30s a very good et.
