Re: 440 short block question.
[Re: wesgtx440]
#1624400
05/24/14 02:29 PM
05/24/14 02:29 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Yes. .020 440 4.320/is STD. 400 4.340 bore. Don`t know about the exact deck height,but I have seen it done before. Do the math and be SURE its what you want before spending your money
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1624402
05/24/14 05:26 PM
05/24/14 05:26 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I don't think You need much clearancing unless it has aluminum rods Then you would see it at the bottom of the cylinders..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: wesgtx440]
#1624403
05/24/14 05:27 PM
05/24/14 05:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thank you for the info. The crank has an 8 bolt flange and I see some minor grinding that has taken place on the inside of the block, looks like they ground flashing off more than clearance marks. I'm new to stroker engines so what should I look for as far as clearance marks go for the crank or as long as it turns freely and does not hit is that all that's needed?
With a 4.15 stroke I dont think you have to notch the bottom of the bores if you use a chevy rod... so you might not see anything for clearance grinding
