Transbrake transmission brand choice, 727
#1624350
05/24/14 07:53 AM
05/24/14 07:53 AM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
I am sick to death of creeping on the footbrake and scoring cherries at the strip , So i guess it is time to go to the darkside and get a transbrake . Choices i see are Cope or ATI and a vert from the trzns supplier. Car is around 3780lbs with me in it, 4.1 strange dana and 275/60R15 Hoosier or MT Pro tyres. Car is bracket raced , best of 10.96@121plus. 60 averaged up till the last set of tyres at 1.52/3 . I took the power brakes off due to booster and vac pump failures , manual aren't holding high enough . Price is part of the deal, especially as i am in Oz and i need to convert and pay bank fees and get it here . Cope is $2750 , ATI $2200 . Plus vert . Any thought or suggestions. Currently have B&M street strip trans fitted with Griner manual valve body and 5100 stall Dynamic vert. Oh and it is also my daily driver Thanks in advance , Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Transbrake transmission brand choice, 727
[Re: tex013]
#1624354
05/24/14 12:29 PM
05/24/14 12:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Put a smaller piston master cyl on it.. your foot travel will be a bit more BUT the pressure goes higher for better holding... also if you have disc brakes on the rear drum brakes HOLD better on the line.. but disc brakes stop you better
[Re: tex013]
#1624355
05/24/14 01:17 PM
05/24/14 01:17 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
A&A TB VB here. Get it from the teacher! Very dependable. Don
[Re: cudadon]
#1624356
05/24/14 09:52 PM
05/24/14 09:52 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I run a griner. Never a problem and its quick!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: vc360]
#1624359
05/25/14 04:48 AM
05/25/14 04:48 AM
tex013
Sydney,Australia
Thanks for the replies, Will contact Cope next week , ATI dont seem to have many takers . Ian , line lock i am not sure will help as i drive through the brakes at about 2800 . MrPeabody , have 1" master already and pedal is low now . Have 10" drums on the rear . Have tried a 2step but the car seemed to leave faster without it. May have to try again. Vc , is that your barracuda? Wasnt that run here in Sydney at Mopar Rumble ? Looked great , will call Brinks thanks for the contact numbet .
Tex
[Re: tex013]
#1624360
05/25/14 07:16 AM
05/25/14 07:16 AM
Posts: 426 Cairns Queensland Australia. T...
vc360
Tex
Hi Tex yes that was us, me and my father drove down from Cairns for it. We have been to mopar Sunday a few times and thought we would go to the rumble instead. Personally I would just send him your trans, freight would only be 150 max each way?
Darren
