Transbrake transmission brand choice, 727 #1624350
05/24/14 07:53 AM
05/24/14 07:53 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
I am sick to death of creeping on the footbrake and scoring cherries at the strip , So i guess it is time to go to the darkside and get a transbrake .
Choices i see are Cope or ATI and a vert from the trzns supplier.
Car is around 3780lbs with me in it, 4.1 strange dana and 275/60R15 Hoosier or MT Pro tyres. Car is bracket raced , best of 10.96@121plus. 60 averaged up till the last set of tyres at 1.52/3 .
I took the power brakes off due to booster and vac pump failures , manual aren't holding high enough .
Price is part of the deal, especially as i am in Oz and i need to convert and pay bank fees and get it here .
Cope is $2750 , ATI $2200 . Plus vert .
Any thought or suggestions.
Currently have B&M street strip trans fitted with Griner manual valve body and 5100 stall Dynamic vert.
Oh and it is also my daily driver
Thanks in advance ,
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Transbrake transmission brand choice, 727 [Re: tex013] #1624351
05/24/14 08:03 AM
05/24/14 08:03 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
you could put a line locker on it , or call joe from tranzact
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Transbrake transmission brand choice, 727 [Re: tex013] #1624352
05/24/14 08:17 AM
05/24/14 08:17 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
go for Cope cuz, i'm just across the ditch & Cope is easy to deal with down this end of the globe. he'll ship it what ever way you ask & he's good on the advice when you ring & order stuff.
Re: Transbrake transmission brand choice, 727 [Re: rebel] #1624353
05/24/14 12:16 PM
05/24/14 12:16 PM
fresno ca
mikeysmopars Offline
fresno ca
Same problem here and went to a two step and no more rolling
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Transbrake transmission brand choice, 727 [Re: tex013] #1624354
05/24/14 12:29 PM
05/24/14 12:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a smaller piston master cyl on it.. your foot
travel will be a bit more BUT the pressure goes higher
for better holding... also if you have disc brakes
on the rear drum brakes HOLD better on the line..
but disc brakes stop you better
Re: Transbrake transmission brand choice, 727 [Re: tex013] #1624355
05/24/14 01:17 PM
05/24/14 01:17 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
A&A TB VB here. Get it from the teacher!
Very dependable.
Don
Re: Transbrake transmission brand choice, 727 [Re: cudadon] #1624356
05/24/14 09:52 PM
05/24/14 09:52 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I run a griner. Never a problem and its quick!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Transbrake transmission brand choice, 727 [Re: HOTMOPR] #1624357
05/24/14 11:07 PM
05/24/14 11:07 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
griner
Re: Transbrake transmission brand choice, 727 [Re: tex013] #1624358
05/25/14 12:07 AM
05/25/14 12:07 AM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
Car is around 3780lbs with me in it, 4.1 strange dana and 275/60R15 Hoosier or MT Pro tyres. Car is bracket raced , best of [Email]10.96@121plus.[/Email] 60 averaged up till the last set of tyres at 1.52/3 .
Thanks in advance ,
Tex
Call Tony at Brinks Performance in Townsville. He did mine no trouble been there over 6 years now and he does a lot for the Brisbane based guys too.
He has griner valve bodies in stock with all the other gear you need.
07 47798288
www.brinksperformance.com.au
Re: Transbrake transmission brand choice, 727 [Re: vc360] #1624359
05/25/14 04:48 AM
05/25/14 04:48 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thanks for the replies,
Will contact Cope next week , ATI dont seem to have many takers .
Ian , line lock i am not sure will help as i drive through the brakes at about 2800 .
MrPeabody , have 1" master already and pedal is low now . Have 10" drums on the rear .
Have tried a 2step but the car seemed to leave faster without it. May have to try again.
Vc , is that your barracuda? Wasnt that run here in Sydney at Mopar Rumble ? Looked great , will call Brinks thanks for the contact numbet .
Tex
New best MPH 130.32
Re: Transbrake transmission brand choice, 727 [Re: tex013] #1624360
05/25/14 07:16 AM
05/25/14 07:16 AM
V
vc360 Offline
vc360  Offline
V
Tex
Hi Tex yes that was us, me and my father drove down from Cairns for it. We have been to mopar Sunday a few times and thought we would go to the rumble instead.
Personally I would just send him your trans, freight would only be 150 max each way?
Darren
