how to hook up an alt idiot light ( Led ) on a Mopar
#1624073
05/23/14 02:58 PM
05/23/14 02:58 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
what you read... is it posible to hook up an alt idiot light ( led ) on an original Mopar charging system ?
Re: how to hook up an alt idiot light ( Led ) on a Mopar
[Re: John_Kunkel]
#1624077
05/23/14 04:19 PM
05/23/14 04:19 PM
NachoRT74
Valencia, España
Wow! John! I thought it was to be way easier than that LOL
but I'm noticing it dims out with voltage variation... aren't Delco alts simply an ON/OFF light if works or not ?
[Re: John_Kunkel]
#1624079
05/24/14 02:22 AM
05/24/14 02:22 AM
NachoRT74
Valencia, España
eeehm, not... hundred bucks for just make to work an idiot light is insane LOL
Delco alternator, I think will stay on car LOL... if not... diodes and resistor combo for it
[Re: west]
#1624081
05/24/14 11:39 AM
05/24/14 11:39 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
You could do it with a zeener diode and a relay. The older GM and Fords used to do it by putting battery volts on both sides of the idiot lite once it started charging. Some had a seperate stator circuit from the alt that was used to work the lite relay in the voltage regulator and for many years GM used a diode trio in their internal reg alts. But you could put the lite on a relay and then use a zeener diode that would pass curent at about 13.0 volts to work the relay and turn the lite out. Ron
[Re: BDW]
#1624085
05/24/14 01:51 PM
05/24/14 01:51 PM
NachoRT74
Valencia, España
yes confirmed... it load on the reply once you open the link ( mostly sure protected files ) Quote:
Put this in your ashtray
"LCD Cigarette Lighter Voltage Digital Panel Meter Volt Voltmeter Monitor for Auto Car Truck (1piece) "
http://www.amazon.com/dp/B0092KVYGI/ref=...3BAMX&psc=1
a voltimeter is installed on cluster, no need for that
[Re: NachoRT74]
#1624086
05/24/14 02:07 PM
05/24/14 02:07 PM
NachoRT74
Valencia, España
still wondering how to wire it, because it seems linked to regulator + lead, and with key on, but alt not spinning, could short out the system.
I guess the original Delco regulator jumps in and out the ground accordingly
[Re: NachoRT74]
#1624087
05/24/14 03:42 PM
05/24/14 03:42 PM
Posts: 4,748 Florida
BDW
So this is truly an idiot light, for someone who can't look at existing gauge. Put a reminder alert on his IPhone, "look at voltmeter", set for once a week.
[Re: BDW]
#1624088
05/24/14 06:26 PM
05/24/14 06:26 PM
NachoRT74
Valencia, España
LOL, quite so.
But actually is mainly because I want to make work all leds on panel. My friend is installing double electric fans too and mech gauge, so the sender wire will be used to light up when the second fan turns on at a higher temp
[Re: NachoRT74]
#1624089
05/26/14 05:06 PM
05/26/14 05:06 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I like the look...I already made a gauge panel myself for this Roadrunner...Nothing crazy, just Turn signal and High Beam. Under the dash pad where the driver can see them only....In the ash tray, two more LED push buttons (Aicraft quality) for Electric Fan and Rear Defroster.
What does "B" and "G" mean on this panel you have? The "x" is fan? The exclamation point is "check engine" maybe?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1624090
05/27/14 11:34 AM
05/27/14 11:34 AM
NachoRT74
Valencia, España
Yes... that's the way I'll be using G-Generator/alternator B-Brakes X-Fan, which since electric fans will be used with dual fan setup with two temp senders, I'll make it work when second fan turns on. !-Oil here is how it looks oil and temp are mechanical. Got a voltage gauge.
