Re: 69 dart wiring
[Re: purple monster]
#1623863
05/22/14 10:19 PM
05/22/14 10:19 PM
RapidRobert
when you say you have power under the hood you are only referring to jumping the "batt" to the "sol" terminal next to it on the starter relay & it cranked but did not start correct? seperate the bulkhead half that has the fusible link which is the main power going in from the battery & see if you have fire on the eng side bulkhead half brass terminal. Then jump fire to the brass terminal on the other bulkhead half & see if power is restored to the inside of the car & holler back
