Page 1 of 8 1 2 3 4 5 6 7 8
Requesting guidance on a new build.... #1623120
05/21/14 05:49 PM
05/21/14 05:49 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
I'm starting a new build for drag racing, going bigger, and would like some insight/opinions on a combination that's been around a while. A 572. I've got an aluminum KB block on order. It should be here shortly. I have a set of original B1's with T&D rockers. They've had minor port work done. Mainly to get the same CFM out of each port. I will be running carburated alcohol. Hopefully before too long ill have the info on what the heads flow so I can get a new Bullet cam ordered. Any info or insight would be greatly appreciated.
Oops I almost forgot. It will be going in my 68 Dart(drag race only). It has an ATI powerglide and Dana 60 with Moser internals. It has 4.56's in it now but will be changed over to 4.30's.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623121
05/21/14 06:14 PM
05/21/14 06:14 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I sounds like you are on your way to a nice 8 second combo. The B1 heads stock aren't much to talk about stock but with some gentle massaging will respond well. Now fill in some blanks for us on car weight, planned convertor, and so on.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Requesting guidance on a new build.... [Re: pittsburghracer] #1623122
05/21/14 07:22 PM
05/21/14 07:22 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
My 68 Dart had a 556 Mega-block in it. I wish I could take credit for it but I bought it that way. It was to have only 20 passes on a fresh motor. Buyer beware! The motor was way tired and had to be gone thru. bla bla bla... Anyways the car weighs 2835 with we in it. The converter stalls out 5300ish. My Dart is a big tire car=32x14.5w, ladder bar set up. That may have to be changed to a 4-link. Its a full chassis car.
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623123
05/22/14 07:13 AM
05/22/14 07:13 AM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
So any suggestions on who I should go with on the pistons, rods, and crank?
I want to keep the max RPM to around 7000 to 7100, if that helps. If there is something I should keep in mind as well, please speak your mind.
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623124
05/22/14 02:15 PM
05/22/14 02:15 PM
What I know about methanol is to shoot for 15.0 to 1 or slightly higher for drag racing. I have freshen a 572 race gas motor that had 15.0 to 1 with flat tops with a set of 440-1, I don't remember the CC of the heads though I like and use steel rods, that compression ratio is not hard to achieve with a big C.I. motor with flat tops with valve reliefs I had a set of B1 with big combustion chambers, around 72 CC, Koffels wanted to make them 51 or 52.0 CC , if I'm remebering correctly Check your CC first before ordering pistons
Re: Requesting guidance on a new build.... [Re: Cab_Burge] #1623125
05/22/14 02:32 PM
05/22/14 02:32 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Cab_Burge-
Yeah I've been wanting to run steel rods. What brand do you recommend? Also piston brand? I would like to get some life outta this girl too. I know it can be done. I just need to be particular on the build and parts used. The major dilemma, of course, is I don't have a bottomless wallet to fund my horrible addiction.
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623126
05/22/14 04:49 PM
05/22/14 04:49 PM
PA.
"Little"John
"Little"John
PA.
I used Wisco Pistons in my 572 and they were ordered with the 440-1 valve reliefs and Tom Hemphile cut them for my B1 valve reliefs so I could run either head. My Daytona ran 8.48@159mph with the Indy heads and very low compression and should be very low 8's I would think with the B1 heads when I get the car back out. I had a VERY NICE set of Crower rods but the rod bolts wouldn't clear the cam so I used a set of K1 rods with all the upgrades but I don't beat the piss out of my stuff for that last few hundredths.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Requesting guidance on a new build.... [Re: pittsburghracer] #1623127
05/22/14 05:08 PM
05/22/14 05:08 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
pittsburghracer-
What rod journal size are you using? K1 rods look very nice. I've never held one in my hand. Just seen pics. Have you heard of Molnar rods? I've been kinda checking them out. I would LOVE a set of Corrillo's but my wallet doesn't.
I don't like beating the hell out of my stuff either. That's why I've opted to run lower RPM.
BTW... how heavy is your Daytona? etc....
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623128
05/22/14 05:41 PM
05/22/14 05:41 PM
PA.
"Little"John
"Little"John
PA.
pittsburghracer-
I bought my Calias crank from Dan at Performance Only. He tried to talk me into ordering it with the Chevy journal but I already had this set of rods and I couldn't use them anyway. STUPID mistake on my part as I should have ordered the one he suggested. My Daytona is 2350-2400 pounds, powerglide with stock 1.76 gear-set, and a 4.30 rear gear. I would suggest staying away from an I beem rod in a budget rod (go with H beem) and get the upgraded rod bolts for cheap insurance.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Requesting guidance on a new build.... [Re: pittsburghracer] #1623129
05/22/14 05:59 PM
05/22/14 05:59 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Your Daytona is quite a bit lighter than my Dart. My glide has a 1.76 gear set in it as well.
Have you seen any issues at all with the 572? anything to pay particular attention to? Or needs to be done differently when building one? Sorry for all the questions...
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623130
05/22/14 06:22 PM
05/22/14 06:22 PM
PA.
"Little"John
"Little"John
PA.
Sorry I can't give you a lot of info as I only had about 8-10 passes on it and an oil line broke and I put the car on its roof. Not bad but bad enough. Never had a chance to run it in good weather and I had a fuel pressure issue with a brand new Barry Grant 400 pump. The cam was spected out by Tom H. for my B1 heads and more compression so it was wrong for this combo but it still ran half decent.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Requesting guidance on a new build.... [Re: pittsburghracer] #1623131
05/22/14 06:31 PM
05/22/14 06:31 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Oh crap! that makes my sick. Sorry man....
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623132
05/22/14 06:52 PM
05/22/14 06:52 PM
PA.
"Little"John
"Little"John
PA.
Thanks. I bought my Duster 2 years before that happened and never even sat in the car as my Son (Matt) was driving it while he worked on his Duster. I wrecked in September and I let him finish the year but I told him to get busy on his car as I was bumping him out of the seat soon. I turned my Duster into and "oldman" car removing the fiberglass doors and installing stock ones with wind up windows, alternator, and a bigger fuel cell. I built a nice pump gas 408 and go out and run 10.0's in it. Fun car to race and very simple. I drive it in the enclosed trailer, climb out the window and tie it down for the ride home.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Requesting guidance on a new build.... [Re: pittsburghracer] #1623133
05/22/14 06:57 PM
05/22/14 06:57 PM
PA.
"Little"John
"Little"John
PA.
My ride now.
My Daytona the day before I wrecked it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623134
05/22/14 07:11 PM
05/22/14 07:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the 572 and original B1s your gonna need to be ported
pretty decent to stay with that ci and on alky... yes
I would stay with a H-beam rod... compression wise I
would stay in the 14.5-15.0 range... a bracket car
likes the compression if you have to play the line
on the top end(compression responds quicker)... on
the cam I would wait and see what the head flow looks
like before you look at cams
Re: Requesting guidance on a new build.... [Re: MR_P_BODY] #1623135
05/22/14 07:26 PM
05/22/14 07:26 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
pittsburghracer-
That's way cool!!
On C-16 race fuel, my old fat girl with the 556 in it ran [Email]9.27@143.35[/Email] with a 1.31 60' [Email]DA@3622'[/Email]
Were you running a vacuum pump on yours?
Greg
Re: Requesting guidance on a new build.... [Re: MR_P_BODY] #1623136
05/22/14 07:34 PM
05/22/14 07:34 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
MR_P_BODY-
Ported pretty decent, like what are we talking?
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623137
05/22/14 08:25 PM
05/22/14 08:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
MR_P_BODY-
I would look at a full port job or close to it..
something like 360cfm or more... the alky takes up
volume in the port since you run 2X the amount of alky
vs gas
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623138
05/22/14 08:34 PM
05/22/14 08:34 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
Not that i can offer any advise just that im doing a similar project as you, B1 572 on alcohal, comp. little over 15.1, 2 1/4 custom headers 4.10 dana on 14.5x32 car weighs about 2500lb
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623139
05/23/14 01:33 AM
05/23/14 01:33 AM
PA.
"Little"John
"Little"John
PA.
pittsburghracer-
That's way cool!!
No vacuum pump on mine. I'm a VERY budget orientated bracket racer. Taught myself at the age of 20 how to build engines and port heads after waiting 13 months for my first engine to get built. 58 now and still enjoy racing every chance I get.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
