Re: 440 cast crank balance
[Re: moparpaul66]
#1620780
05/16/14 08:27 PM
05/16/14 08:27 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In some cases, the shop that did the balancing will stamp a work order number somewhere on the crank; if you can find it and the shop that did it they will probably have records.
[Re: moparpaul66]
#1620781
05/17/14 12:35 PM
05/17/14 12:35 PM
RapidRobert
As said I would ASSuME that a prior owner neutral balanced it (any indications that it ain't stock/ rebuilt/30 over etc). I'm assuming the long block is together? If so I'd likely install it with a neutral dampener/tc/flexplate & hope that it is smooth. If it is apart or if you wanted to be proactive & take it apart which might not be a bad idea (I'd rather know now then later & have to pull it out/apart & tear into it) then you'd need to take the crank and 1 rod/piston/ring/bearings(s) assy in so he could weigh it/spin the crank & see if it is balanced to that assy. EDIT you'd need to take in a neutral dampener & likely the flexplate/bolts also (ask the guy) & ask him if he needs the big bolt/washer for the dampener also
[Re: jose jones]
#1620785
05/21/14 12:46 AM
05/21/14 12:46 AM
RapidRobert
Most people dont care for them for some strange reason but I dont think there is a problem hotrodding them
