Dominators on M1 tunnel ram #1620773
05/16/14 07:31 PM
05/16/14 07:31 PM
Zumbrota,MN
als499 Offline OP
als499  Offline OP
Zumbrota,MN
Has anyone tried running 4500 Holleys on the Mopar M1 tunnel ram? I just set a 4500 gasket on an M1 tunnel Ram top and it looks like the bolt holes line up if you twist the carb. a bit and open up the opening, there is plenty of material. Not sure if Chrysler designed this to happen but it looks pretty easy to do.
Re: Dominators on M1 tunnel ram [Re: als499] #1620774
05/16/14 07:32 PM
05/16/14 07:32 PM
Zumbrota,MN
als499 Offline OP
als499  Offline OP
Zumbrota,MN
In the works... I guess you could also try this on a Weiand Hi Ram.
Re: Dominators on M1 tunnel ram [Re: als499] #1620775
05/16/14 08:22 PM
05/16/14 08:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
See if the carbs clear end to end
Re: Dominators on M1 tunnel ram [Re: als499] #1620776
05/16/14 08:43 PM
05/16/14 08:43 PM
dogdays Offline
dogdays  Offline
I bet they're going on sideways.
R.
Re: Dominators on M1 tunnel ram [Re: dogdays] #1620777
05/16/14 08:50 PM
05/16/14 08:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
R.
I agree but if thats a 4150 manifold then I dont think
they fit on sideways without working on the mount holes..
thats what I remember anyways
