Re: Burst Plate(s) on Tunnel Ram [Re: Hemi Allstate] #1620311
07/12/14 12:28 AM
07/12/14 12:28 AM
Here
jcc Offline
jcc  Offline
Here
I myself am just wondering how effective the burst plates are in the front side and the rear side of the RR intake, seems to me they would be more effective if they were on top of the lid more near the center?
I cannot answer your question with my own experience, as I have yet to use my RR intake. However, I placed them where they are, as recommended by a board member, with a lot of experience with the RR intakes and modifications to the same.
Mark
Shooting from the hip here, but I think it might be important to try and not compare an intake back fire to a normal combustion chamber ignition event, mainly not compressed to 180+psi prior to ignition and only 2"? max flame travel vs a partial manifold vacuum with 12 or more inches of flame travel. I suspect also that we are not talking long ram style intakes which would develop a certain amount of column inertia during a backfire. The most important point I think to consider is the large partial vacuum intake plenum likely works as a pretty good pressure shock absorber as the backfire begins, and the burst reliever has a lot more time to vent this pressure as the backfire takes place, and the pressure is pretty well distributed because of the relatively large volume, and where the burst panel is located would should not be as critical, more will it flow enough outflow to keep pressure spike workable. Ideally though more centrally located would be best, but knowing in advance which cyl starts the back fire would also mean one knows which cylinder to focus on to prevent it, if it's only one. As much as I may be minimizing the pressures, it is still a large energy pulse. I also have a bridge for sale.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620312
07/12/14 12:32 AM
07/12/14 12:32 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Is this what your looking for but in a 10-24 size?
You want to use a 6/6 Nylon
Re: Burst Plate(s) on Tunnel Ram [Re: roadhazard] #1620313
07/12/14 01:01 AM
07/12/14 01:01 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Hi Greg,
I will check and see exactly what I have out in the shop tomorrow. I think they are 10-24. Time for a cruise in the other 66 Dodge!
Re: Burst Plate(s) on Tunnel Ram [Re: Hemi Allstate] #1620314
07/12/14 08:47 AM
07/12/14 08:47 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Mark
It should not matter where it is. The pressure will be equal in all direction. It is similiar to a relief valve in a hydraulic system. The relief valve can be anywhere on the pressure side of the system.
Re: Burst Plate(s) on Tunnel Ram [Re: mac56] #1620315
07/12/14 11:39 AM
07/12/14 11:39 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Try Mcmaster-Carr for the nylon machine screws. Here is the online page:
http://www.mcmaster.com/#machine-screws/=ssz3ew
Ar 6.42 for a bag of 100 1" long 10-24 in black you could replace them every 3 months for several years if you are worried about UV.
Since you are up in Babylon you can use UPS instead of the usual fight to convince companies (Mcmaster is actually better than most) to use the USPS and that the USPS CAN deliver to a USPS Post Office Box.......
Now you guys have me all nervous about my Weiand tunnel ram.....
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Burst Plate(s) on Tunnel Ram [Re: roadhazard] #1620316
07/12/14 11:46 AM
07/12/14 11:46 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Might help if I included the link
http://www.amazon.com/dp/B00137OQTU/ref=...ASIN=B00137OQTU
Re: Burst Plate(s) on Tunnel Ram [Re: roadhazard] #1620317
07/13/14 03:21 AM
07/13/14 03:21 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I see that is the metric equivalent. Is 6/6 UV protected? We have major issues with white nylon zip ties out here. They become brittle in less than a year when fully exposed. Being a streeter our car spends time parked at the growers market, etc. throughout the summer.
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620318
07/13/14 10:30 AM
07/13/14 10:30 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yes it's metric, just attached the link to see if it's the same head type your looking for (tapered?). They seem to be a little difficult to locate in SAE Tapered Seat.
The 6/6 Nylon is what they make valve stem seals out of, however they are 30% glass filled (fiberglass). Nylon valve seals are tough as nails and live in a very harsh environment hence my recommendation for 6/6 Nylon. I really have no idea what they make Zip Ties out of. Probably a lot of re-ground junk would be my guess.
My Yahoo search for "6/6 Nylon Machine Screws" turned up more than Google. You can also search "Images" and follow the links
Re: Burst Plate(s) on Tunnel Ram [Re: roadhazard] #1620319
07/13/14 11:28 AM
07/13/14 11:28 AM
P
Porter67 Offline
Porter67  Offline
P
As stated they are not made for a full on nitrous backfire, however they do a fine job on a big plenum intake on choke less cold starts or until one gets the timing/carbs correct.
They do work, the self resetting part is 90% true so put them where you can reach them as the rubber O ring can get moved out of place.
I dont think the few brief cranking coughs back through the intake that did release through the plates would of been strong enough to hurt a carb.
But if it saves things one time, they were worth the cost and install time.
I like the plastic bolt idea on a track car that calls for it.
Re: Burst Plate(s) on Tunnel Ram [Re: Porter67] #1620320
07/13/14 02:04 PM
07/13/14 02:04 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
McMaster-Carr also sells aluminum and titanium bolts and studs. Just sayin'.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Burst Plate(s) on Tunnel Ram [Re: roadhazard] #1620321
07/13/14 03:06 PM
07/13/14 03:06 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I'll do a bit more research. My prior investigation also turned up lots of metric options for "flat" (tapered) machine screws as well. As far as the zip ties we use they are black UV resistant and about 50 cents a piece. They may be made out of recycled junk but they do their job in very harsh environments for years and years without becoming brittle or shearing. I'll look into that as well.
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620322
07/13/14 04:10 PM
07/13/14 04:10 PM
Here
jcc Offline
jcc  Offline
Here
Almost anything black nylon has inherent UV resistance greater then white Nylon. can;t imagine under hood UV on a bolt head of nylon would ever succumb to UV issues. They are cheap enough to toss rather then reuse.
Awhile back it was mentioned the manifold issues are similar to "hydraulics", if you discount the the concept that a liquid is for all intents and purposes non compressible and air is, and the speed of the pressure spike is much faster in a liquid (for example speed of sound in air 343 m/s vs 1461 m/s in oil), allowing less time for flow to displace volume/pressure thru the burst panel.
Nobody has an issue with a partially separated TR top acting like a WO stuck throttle?
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620323
07/13/14 05:53 PM
07/13/14 05:53 PM
New York
polyspheric Offline
polyspheric  Offline
New York
So sad... only 2 choices:
Do nothing (always popular), or spend $75 × how many?
No engineers here? Not sure which side of the boat hull to put the patch on?
Since there isn't any positive pressure unless something goes wrong (the complete opposite of a blower manifold) a holesaw and a big piece of duct tape works just fine. Fails instantly with any cough (which the small panels won't do until their pre-set is reached).
Wonder why they put stuff down a demo hole after the dynamite? Because the expansion in the first few milliseconds is very important.
Just imagine the facial expression when a sneeze wrecks the carbs, dents the hood, bends up the linkage and tears the fuel line off!!!
Well, except for the annoying comments of the skin-packaged billet color-anodized speed equipment enthusiasts...
[/rant]
Boffin Emeritus
Re: Burst Plate(s) on Tunnel Ram [Re: jcc] #1620324
07/14/14 04:46 AM
07/14/14 04:46 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
1) My tunnel ram will not be under the hood. UV protection is important.
2) If the car backfired and popped the manifolds lid off the mixture is going so lean it's not running anymore...I think?
Re: Burst Plate(s) on Tunnel Ram [Re: polyspheric] #1620325
07/14/14 04:51 AM
07/14/14 04:51 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
[/rant]
I'm not sure if you are saying I am smart of retarded for adding burst plated. I have considered playing with the springs to see how light I can go without causing a vacuum leak.
If you wanted to avoid bending butterflies on your Quickfuels at 6am on the way to work when the lean misfire occurs (stick car) what would you do? Please write this response in English. I don't speak /rant.
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620326
07/14/14 07:16 AM
07/14/14 07:16 AM
P
Porter67 Offline
Porter67  Offline
P
You can set them as far as the small lock nuts will back out against the stud/bolt but it makes them harder to reset themselves.
Possibly if a person used RTV or something to keep the o ring in place on the one side it fits in it might be the ticket.
I have mine in each side and even with them fully cranked so they can just open a bit does let them reset and still work. Last time I popped a bit the one I could see just was a quick small flash then reset.
Re: Burst Plate(s) on Tunnel Ram [Re: Porter67] #2703376
10/03/19 11:44 AM
10/03/19 11:44 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I am bringing this thread back from the dead after a mishap this weekend at the local track. We had a no prep deal at #medforddragstrip and one of, if not the nicest car there had a n20 backfire and blew a lexan t-ram carb scoop all over the track. We were the next car in staging and had lexan chips raining all over about 150' from the starting line.
Car had no burst plates and I was told steel fasteners. Read this thread; protect that $$$ induction system!
Thank you for reading this PSA.
