Small block to 4 speed setup- need parts list #1619607
05/12/14 11:48 PM
05/12/14 11:48 PM
Kentucky
dfsmopars Offline OP
Kentucky
Installing a 318 ci into a custom built frame street rod set up. Chopped, channeled, Corvette front & rear suspension with 18" wheels. Question is if you were swap meet shopping for trans, bell housing, pedals, hydraulic cylinder and what-not what would you go after for a complete 4 speed set up behind a 300 hp small block? This is not a budget build but going out and buying everything off the shelf new is not an option. Some new thrown in with used is ok.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Small block to 4 speed setup- need parts list [Re: dfsmopars] #1619608
05/13/14 12:48 AM
05/13/14 12:48 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I'd like to see pics of the project.
Re: Small block to 4 speed setup- need parts list [Re: dfsmopars] #1619609
05/13/14 02:51 PM
05/13/14 02:51 PM
Kentucky
Kentucky
OK, here is the current status. Now, how about some suggestions?
Re: Small block to 4 speed setup- need parts list [Re: dfsmopars] #1619610
05/13/14 03:20 PM
05/13/14 03:20 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
you might have been better off posting in the street rod section. I am putting a 318(I should have built a 360 right?)/4speed in my 47 Desoto. I`ve already fit all the parts in and took it back apart to paint it. its an 833OD/bellhousing/shifter from an early 80`s truck. I moved the master cyl. to the fire wall along with the clutch master cyl. I used the brake and clutch pedal from a ram 50(1988 maybe?) they bolt to the firewall and the master cyls. bolt to them. I modified mine to work with a late 70's dodge truck brake master cyl. and the clutch pedal to use the 3/4" master cyl. from speedway motors. I`m using the pusher type slave cyl. from speedway motors too(you will have to make your own bracket. I think you can use the pedals/master cyls. from an early Dakota too.
Re: Small block to 4 speed setup- need parts list [Re: 65rbdodge] #1619611
05/13/14 03:59 PM
05/13/14 03:59 PM
scratchnfotraction Offline
well you can use any v-6 hydro bell with a a535/ax15 from a DAK, not very strong though. ax15 has it own 7 bolt specific hydro bell bell for v-6
a NV3500 5 speed from a 5.2/5.9 Dak is much stronger and should hold up fine with that HP/weight ratio. a 94-up 1500 nv3500
I happen to like my hughes roller cam 318/NV4500 5 speed in my 2x 85 D150 stepside. granted it is a granny gear first with a OD 5th gear..but the 235/70/15 tires with a 3.21 gear make the granny gear just right for a fast off the line jump and pretty fast thru the gears for a 4000lbs truck. about like any stock BB 4-speed B-body IMHO.
the spare 88-d100 v-6 hydro bell I have will bolt up the older car 833/833OD car/truck 4 speeds and give you a stock 88-93 hydro clutch system.
be aware some of the hydro bells are NV4500 specific even though they have duel bolt patters...IIRC it is for a 435 4-speed or the NV4500 5 speed only.
used the 88 v-6 fly wheel and clutch for a 93 d250 NV4500 2x 5.9 gas engine
