What Size O-Ring - 727 Dipstick #1618823
05/11/14 03:37 PM
05/11/14 03:37 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
What size O-Ring was OEM for 727 dipsticks? There is one that is close in my O-Ring kit, but it is a little small. Mine is leaking so I would like to get the correct one if possible.
Re: What Size O-Ring - 727 Dipstick [Re: markz528] #1618824
05/11/14 05:55 PM
05/11/14 05:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
.750" OD X .100" thick.
Re: What Size O-Ring - 727 Dipstick [Re: John_Kunkel] #1618825
05/11/14 06:07 PM
05/11/14 06:07 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Thanks! I guessed and used a 113 (.755" OD and .103 thick). So I should be good to go.
I will know soon if I fixed the leak.
Re: What Size O-Ring - 727 Dipstick [Re: John_Kunkel] #1618826
05/11/14 06:23 PM
05/11/14 06:23 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
is it an o-ring I was thinking it was square/lathe cut?
Re: What Size O-Ring - 727 Dipstick [Re: snuggles] #1618827
05/11/14 07:16 PM
05/11/14 07:16 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
That's what they look like when they get old and deformed..........
Re: What Size O-Ring - 727 Dipstick [Re: markz528] #1618828
05/11/14 07:41 PM
05/11/14 07:41 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
that describes a few people around here..
I am truckless..
Re: What Size O-Ring - 727 Dipstick [Re: 340SHORTY] #1618829
05/11/14 08:30 PM
05/11/14 08:30 PM
SE PA
Yellow Fever Offline
SE PA
Re: What Size O-Ring - 727 Dipstick [Re: Yellow Fever] #1618830
05/11/14 08:55 PM
05/11/14 08:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I like the boot seals that the later transmissions use.
http://www.ebay.com/itm/131071796547?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
You can't use that without modifying the dipstick.
when I put together a 727 I makes sure the dipstick hole in the trans and the dipstick are oil free , put on the o ring the tube and put a big bead of copper type RTV around the tube below the o ring , put the tube it and let it sit over night in it's secured position , no leaks .
Re: What Size O-Ring - 727 Dipstick [Re: markz528] #1618831
05/11/14 08:58 PM
05/11/14 08:58 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
A friend picked up one from a dealer and I thought it was square. My memory isn't the best though.
Re: What Size O-Ring - 727 Dipstick [Re: snuggles] #1618832
05/12/14 11:15 AM
05/12/14 11:15 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You're thinking about the trunk lid rollers.
But my memory isn't the best though.
