Page 1 of 4 1 2 3 4
WHAT IS THE TOOL TO SET PINION ANGLES #1618438
05/10/14 07:44 PM
05/10/14 07:44 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
what is the tool name and of the tool manafactor of the tool used to set the pinion angle with the driveshaft it is about 18 in long and you put up against the drive shaft and the pinion to get your angle and where can you get one THANKS
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dragon] #1618439
05/10/14 07:49 PM
05/10/14 07:49 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Digital Level from Sears.
Harbor Freight, Lowes, ACE Hardware, Home Despot (Depot)....
Angle Finder
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dragon] #1618440
05/10/14 07:49 PM
05/10/14 07:49 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I use an angle finder. They come in manual and digital versions. Works like a level. Either has a dial scale that moves as the angle changes, or a digital read out. Sears has them. Get the angle from the driveshaft, then from one of the flat spots on the yoke with it facing parallel to the ground. Subtract the yoke from the driveshaft angle and thats it.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dragon] #1618441
05/10/14 08:26 PM
05/10/14 08:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The real name is called a inclineometer but most
call it a angle finder
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: MR_P_BODY] #1618442
05/10/14 08:31 PM
05/10/14 08:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I use my eye, seems to work pretty good.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Quicktree] #1618443
05/10/14 08:36 PM
05/10/14 08:36 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yaeh with your eyes Im sure that works real well you didn't even see the missing holes on your gaskets
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dusturbd340W5] #1618444
05/10/14 10:04 PM
05/10/14 10:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats because they were missing
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Quicktree] #1618445
05/11/14 12:04 AM
05/11/14 12:04 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
What is the tool that Quicktree uses to set pinion angles? Quicktree.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: DusterDave] #1618446
05/11/14 05:30 PM
05/11/14 05:30 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Oh Lord.............not AGAIN...........LOL!!!
Monte
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Monte_Smith] #1618447
05/11/14 05:34 PM
05/11/14 05:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte
don't worry i'll take the time and teach you next time you are down this way
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Quicktree] #1618448
05/11/14 09:38 PM
05/11/14 09:38 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
this thread will be...............awesome.
i just duct tape an old bubble tire balancer to the windshield and bounce the car until the bubble faces 65 degrees to the southwest.....then subtract for humidity and headlight angles..... DONE . pinion angle set.
And if you take muffler angle into the equation...you're doing it wrong.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: 493_DART] #1618449
05/12/14 12:14 AM
05/12/14 12:14 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Heeeeeere we go.
I use an anglie danglometer.
Yeah, it's got a smallblock.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: MR_P_BODY] #1618450
05/12/14 12:42 AM
05/12/14 12:42 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
i installed those on the 777 at Boeing in the nose gear took every bit of 10mins out of 8hrs to do lol i miss that job but not the cold wet weather
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dragon] #1618451
05/12/14 02:40 PM
05/12/14 02:40 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
iphone with the handy level app
2011 Drag Pak Challenger
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: DusterDave] #1618452
05/12/14 02:50 PM
05/12/14 02:50 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Yep quicktree is the tool to use
got to wonder,is there any kind of ban on exporting the famouns quicktree tool incase i ever need to get my pinionangle set right?
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: 1Fast340] #1618453
05/12/14 06:20 PM
05/12/14 06:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
watch it, i may just send you my tool
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Quicktree] #1618454
05/12/14 07:02 PM
05/12/14 07:02 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Man no one ever needs to hear or even think of that!
The real way to set pinion angle is to adjust the front ride height until the pinion is at 3 degrees down or 7 with a leaf spring. If you can't get the front low enough then raise the back!
Back in the swing of things at Painless again! Great to be back!
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: BJS racing] #1618455
05/12/14 07:16 PM
05/12/14 07:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you know what I really think about pinion angle some of these guys still don't get it..
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Quicktree] #1618456
05/12/14 10:53 PM
05/12/14 10:53 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
AGREED!!! I set the pinion angle relative to the transmission but there are guys that think the method described in the old DC chassis manual is the "one and only way"...."no driveshaft? You can't set pinion angle then" so I've been told...agree to disagree!
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: 496 A-body] #1618457
05/13/14 12:36 AM
05/13/14 12:36 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Plenty of functional vids out on Youtube to show that you set it off of the parallel planes between the tranny centerline and the pinion centerline. Somebody link them up. A picture is worth a thousand words, a vid even more.
The driveshaft can become part of the equation because of overall operating angles. But not likely on our race cars, jacked up 4 wheel drives , yep.
Page 1 of 4 1 2 3 4
