Re: WHAT IS THE TOOL TO SET PINION ANGLES
[Re: dusturbd340W5]
#1618444
05/10/14 10:04 PM
05/10/14 10:04 PM
Quicktree
yaeh with your eyes Im sure that works real well you didn't even see the missing holes on your gaskets
thats because they were missing
[Re: Monte_Smith]
#1618447
05/11/14 05:34 PM
05/11/14 05:34 PM
Quicktree
Oh Lord.............not AGAIN...........LOL!!!
Monte
don't worry i'll take the time and teach you next time you are down this way
[Re: MR_P_BODY]
#1618450
05/12/14 12:42 AM
05/12/14 12:42 AM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
The real name is called a inclineometer but most call it a angle finder
i installed those on the 777 at Boeing in the nose gear took every bit of 10mins out of 8hrs to do lol i miss that job but not the cold wet weather
[Re: dragon]
#1618451
05/12/14 02:40 PM
05/12/14 02:40 PM
Posts: 2,685 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
what is the tool name and of the tool manafactor of the tool used to set the pinion angle with the driveshaft it is about 18 in long and you put up against the drive shaft and the pinion to get your angle and where can you get one THANKS
iphone with the handy level app
2011 Drag Pak Challenger
[Re: DusterDave]
#1618452
05/12/14 02:50 PM
05/12/14 02:50 PM
Posts: 2,578 sweden
1Fast340
sweden
What is the tool that Quicktree uses to set pinion angles? Quicktree.
Yep quicktree is the tool to use
got to wonder,is there any kind of ban on exporting the famouns quicktree tool incase i ever need to get my pinionangle set right?
[Re: 1Fast340]
#1618453
05/12/14 06:20 PM
05/12/14 06:20 PM
Quicktree
watch it, i may just send you my tool
[Re: BJS racing]
#1618455
05/12/14 07:16 PM
05/12/14 07:16 PM
Quicktree
Man no one ever needs to hear or even think of that!
The real way to set pinion angle is to adjust the front ride height until the pinion is at 3 degrees down or 7 with a leaf spring. If you can't get the front low enough then raise the back!
you know what I really think about pinion angle some of these guys still don't get it..
[Re: Quicktree]
#1618456
05/12/14 10:53 PM
05/12/14 10:53 PM
Posts: 369 Indy
496 A-body
Indy
AGREED!!! I set the pinion angle relative to the transmission but there are guys that think the method described in the old DC chassis manual is the "one and only way"...."no driveshaft? You can't set pinion angle then" so I've been told...agree to disagree!
