Page 2 of 3 1 2 3
Re: Power Steering Fluid [Re: John_Kunkel] #1618172
05/12/14 05:45 PM
05/12/14 05:45 PM
Loves Park, IL
HotRodRailroader Offline
Loves Park, IL
lots of fluids can be interchanged. If your purchasing clutch fluid just look at the bottle. It IS brake fluid. Dot 3. So it really is a good question to ask but PS and ATF would not fly in my book. different viscosity and pressure tolerances.
Re: Power Steering Fluid [Re: HotRodRailroader] #1618173
05/13/14 02:47 PM
05/13/14 02:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
So, you're saying that the pressures have changed since ATF was the recommended fluid? FSM's say they're the same. Viscosity? Nope.
Re: Power Steering Fluid [Re: John_Kunkel] #1618174
05/13/14 02:54 PM
05/13/14 02:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When did the factory recommend ATF?
Re: Power Steering Fluid [Re: stumpy] #1618175
05/13/14 04:23 PM
05/13/14 04:23 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Put a manual box on it then these guys can find something else to argue about.
...FAFO...
Re: Power Steering Fluid [Re: stumpy] #1618176
05/13/14 04:52 PM
05/13/14 04:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My '57 FSM specifies ATF Type "A" Suffix "A" as do most from the fifties/early sixties.
Re: Power Steering Fluid [Re: John_Kunkel] #1618177
05/13/14 05:08 PM
05/13/14 05:08 PM
AL
jglen490 Offline
jglen490  Offline
AL
Maybe the FSM requirement has changed sometime in the past 50 years "just" so someone could sell a more expensive PS fluid - but I doubt it.
Just like the change in requirement from the mistake of "use Dexron" in the A604 was corrected to ATF+3 and then ATF+4, experience changes many things; and sometimes without the need to validate that experience in a laboratory setting.
Re: Power Steering Fluid [Re: jglen490] #1618178
05/13/14 05:23 PM
05/13/14 05:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The early ATF contained sperm oil, the use of which was outlawed in the late sixties; this required the development of costly additives to serve as a substitute for the whale oil.
I suspect that the use of dedicated P/S fluid came about because the exotic additives in ATF simply aren't needed in P/S systems. (that doesn't mean it's detrimental to use it)
Re: Power Steering Fluid [Re: John_Kunkel] #1618179
05/14/14 12:20 AM
05/14/14 12:20 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Explain this!
Re: Power Steering Fluid [Re: GODSCOUNTRY340] #1618180
05/14/14 12:35 AM
05/14/14 12:35 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What's it from?
Re: Power Steering Fluid [Re: stumpy] #1618181
05/14/14 09:29 AM
05/14/14 09:29 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
What's it from?
Looks like a p/s reservoir from a hydroboost set-up for a factory plow truck.
...FAFO...
Re: Power Steering Fluid [Re: GODSCOUNTRY340] #1618182
05/14/14 03:36 PM
05/14/14 03:36 PM
AL
jglen490 Offline
jglen490  Offline
AL
Old cap.
Re: Power Steering Fluid [Re: jglen490] #1618183
05/14/14 06:56 PM
05/14/14 06:56 PM
hooziewhatsit Offline
I recently got a rebuilt box for my 72 W200, and asked them about ATF/PS fluid.
"We are good with ATF your system was designed around using ATF for 30 plus years until someone decided they had something better, but any of the p/s fluids are good."
I put in ATF since I had a couple quarts on hand.
Re: Power Steering Fluid [Re: hooziewhatsit] #1618184
05/15/14 12:58 AM
05/15/14 12:58 AM
Nice try Quint, but it's a power steering pump from a 1968 Chebby truck.
Re: Power Steering Fluid [Re: GODSCOUNTRY340] #1618185
05/15/14 06:46 PM
05/15/14 06:46 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I went to a few places today to ask for Castrol GT PS Fluid...every place I went to...the kid pulled Dexron-Mercon III off the shelf...and I shook my head and educated them...the owners of the shops stood by the employee...Finally I drove 45 miles today to a Canadian guy who brings parts from Montreal here...and bought 6 bottles of this stuff. Its been sitting on the shelf so long, the bottles have yellowed.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Power Steering Fluid [Re: Pyper70] #1618186
05/15/14 07:32 PM
05/15/14 07:32 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
There are still some late model cars that call for ATF for the power steering systems, most notably Subaru.
Re: Power Steering Fluid [Re: GTX MATT] #1618187
05/15/14 07:44 PM
05/15/14 07:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Chevy, Subaru? Did any one notice we are discussing power steering fluid in a Mopar which does not recommend ATF usage. Subaru also had a two stroke motor but I wouldn't recommend using a 50:1 blend of gas and oil in our Mopars.
Re: Power Steering Fluid [Re: GODSCOUNTRY340] #1618188
05/15/14 08:06 PM
05/15/14 08:06 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep, Lots of Chevy trucks of that era and Later, had the ATF stamped PS cap. Even saw a similer cap on a Chevy 10 ton Dump truck. Similer pumps but power steering box was huge and expensive.
GM had No worries using Tranny fluid in the PS units. Heck They Even Stamped the Caps.
Re: Power Steering Fluid [Re: stumpy] #1618189
05/15/14 08:11 PM
05/15/14 08:11 PM
Any power steering fluid will work. Be warned that power steering fluid is a much different fluid than ATF. You don't need any high dollar brand. Don't use ATF it wasn't made to be used for steering fluid.
Just reacting to your post stating ATF wasn't made to be used for power steering fluid.
Re: Power Steering Fluid [Re: GODSCOUNTRY340] #1618190
05/15/14 08:14 PM
05/15/14 08:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
We are discussing MOPARs not GM or any other off brand.
Re: Power Steering Fluid [Re: stumpy] #1618191
05/15/14 08:23 PM
05/15/14 08:23 PM
It could be used for power steering but not what is recommended by Mopar or anyone else. I also bet firm feel would not warranty any part failures if you told them that is what you used in the system.
Here you state it's not recommended by Mopar or anyone else. I'd like to agree with you but then we'd both be wrong.
Page 2 of 3 1 2 3
