Brown zinc parts..resto #1617789
05/08/14 06:10 PM
05/08/14 06:10 PM
Sweden
71redcuda Offline OP
Sweden
Hello,
Im looking for a someone who can do the correct factory plating (brown zinc) on a hood latch now when Jules is no longer with us..
Looking for a high quality resto if avalible.
THANKS
Nicklas
Re: Brown zinc parts..resto [Re: 71redcuda] #1617790
05/08/14 08:36 PM
05/08/14 08:36 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Try Scott
Re: Brown zinc parts..resto [Re: 5carguy] #1617791
05/08/14 09:08 PM
05/08/14 09:08 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's the best current source I know of. Stephan.Fournier@videotron.ca
Re: Brown zinc parts..resto [Re: ScottSmith_Harms] #1617792
05/09/14 02:13 AM
05/09/14 02:13 AM
Sweden
Sweden
Thanks! This was the guy who worked with Jules?
Re: Brown zinc parts..resto [Re: 71redcuda] #1617793
05/09/14 02:21 AM
05/09/14 02:21 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, he's a very nice guy.
Re: Brown zinc parts..resto [Re: ScottSmith_Harms] #1617794
05/09/14 03:37 AM
05/09/14 03:37 AM
Sweden
Sweden
Will try him, appreciate the help with this.
Re: Brown zinc parts..resto [Re: 71redcuda] #1617795
05/09/14 07:39 AM
05/09/14 07:39 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
You can also contact Bill @ bmcuda.com - he does them.
Re: Brown zinc parts..resto [Re: 71redcuda] #1617796
05/09/14 07:43 AM
05/09/14 07:43 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
That finish is called Parkerized and you can do it yourself very cheaply. I started doing my own 20 years ago restoring Harley parts. Manganese and Zinc phospating developed by the Parker Chemical Co. way back in the day. All you have to do is soak the cleaned steel(glass beaded or wire brushed and degreased) in the heated solution for a bit and oil it after you pull it out.
http://www.shootersolutions.com
Re: Brown zinc parts..resto [Re: Pynzo] #1617797
05/09/14 12:29 PM
05/09/14 12:29 PM
WI
RestoRick Offline
RestoRick  Offline
WI
As stated by the original poster, these are done with black zinc. It's clear (silver) zinc followed by a chromate bath, brownish black in this case.
Often mistaken for parkerizing or phosphating, but it's most definitely not.
Re: Brown zinc parts..resto [Re: RestoRick] #1617798
05/09/14 12:44 PM
05/09/14 12:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
And also notice that with the assemblies that the OP shows, the parts were not all one color, they need to be disassembled and plated before reassembly.
Re: Brown zinc parts..resto [Re: ScottSmith_Harms] #1617799
05/09/14 11:13 PM
05/09/14 11:13 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
I have always thought hood latches were black phosphate,lots of mopar latches have MMP on them that stands for Modern Metel Products,that was in Loves Park Il. untill they closed in about 2010!
Re: Brown zinc parts..resto [Re: 1970A13] #1617800
05/10/14 02:09 AM
05/10/14 02:09 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
See:
http://www.iccahome.org/
and click on black zinc in left margin. AFAIK, hood safety catches should be black zinc, not phosphated. Black zinc is not so black in many cases.
Re: Brown zinc parts..resto [Re: kentj340] #1617801
05/10/14 02:42 AM
05/10/14 02:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
How to tell the difference between black zinc (or any zinc plating) and phosphate:
Dip a toothpick in a fairly strong acid and deposit a small drop on an unexposed part of the test piece. I use phosphoric acid (Rust Cure) for this, because I always have some, and I know how it behaves on zinc. If tell tale bubbles soon appear, the coating is likely zinc, because zinc is highly reactive with acid. Apply water to stop the reaction, and no harm done.
Mostly you never want to put zinc plated parts in acid, because the zinc will be totally consumed in a fraction of an hour or so, even with a weak acid like vinegar. Zinc plating is usually in the range of only 0.0001" to 0.0002" thick. When doing zinc plating or chromating, HCl is used for a dip cleaner, but the exposure is in seconds.
Re: Brown zinc parts..resto [Re: kentj340] #1617802
05/10/14 07:55 AM
05/10/14 07:55 AM
Tropicalcats Offline
Stephan has my hood and trunk laches and in talking with him I have every reason to expect a quality product. Aside from the correct finish he will disassemble and reassemble with the proper rivets.
He has big shoes to step into but in talking with him and seeing some pics I think he can do it.
Re: Brown zinc parts..resto [Re: Tropicalcats] #1617803
05/10/14 11:13 AM
05/10/14 11:13 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Does RestoRick use the correct rivets?
Re: Brown zinc parts..resto [Re: 1972CudaV21] #1617804
05/10/14 05:22 PM
05/10/14 05:22 PM
Not sure. I know that Stephan worked with Jules and for me that says it all.
Re: Brown zinc parts..resto [Re: 71redcuda] #1617805
05/10/14 08:27 PM
05/10/14 08:27 PM
Portage Wisconsin
Lou_Steger Offline
Lou_Steger  Offline
Portage Wisconsin
Hello,
THANKS
Nicklas
What happened to Jules?
Re: Brown zinc parts..resto [Re: Lou_Steger] #1617806
05/10/14 09:41 PM
05/10/14 09:41 PM
Hello,
THANKS
Nicklas
Jules passed away from cancer. A great loss.
Re: Brown zinc parts..resto [Re: Lou_Steger] #1617807
05/11/14 12:52 AM
05/11/14 12:52 AM
Ont, Canada
moparo Online content
moparo  Online Content
Ont, Canada
Hello,
THANKS
Nicklas
[list]
Stephan has shipped me a latch assembly for the Hemicuda I just finished. was just like opening product from Jules same paper wrap and attention to detail. He also does wiper and heater motors etc.
performancecarrestorations.com
Re: Brown zinc parts..resto [Re: 1972CudaV21] #1617808
05/11/14 01:17 AM
05/11/14 01:17 AM
WI
RestoRick Offline
RestoRick  Offline
WI
I don't do the hood & trunk latches...
