Re: big block distributor caps are to small!!! nitrous guys
[Re: John Burdine]
#1617613
05/08/14 10:07 AM
05/08/14 10:07 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Not sure what brand it is, maybe Stephen will let us know...this is his dad's old KOS cuda.
[Re: John Burdine]
#1617614
05/08/14 10:29 AM
05/08/14 10:29 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Msd adapt-a-cap doesn't fit big blocks? Just switched on my small block.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Plumb Wired]
#1617616
05/08/14 11:18 AM
05/08/14 11:18 AM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
I have been trying to find one of the pre Indy offset distributors offered by NRC (Newman Racing Components)then Predator for awhile now. The ones I do find the sellers want more than they paid for them.
This is that I was thinking. I had the old NRC distributors on both our b1-TS engines and they were great. I think Indy now makes their own version but the price isn;t pretty. Your other option is going to the MSD Front mount belt distributors.
[Re: Diablo]
#1617617
05/08/14 01:46 PM
05/08/14 01:46 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
MSD or Jesel front mount...
[Re: Plumb Wired]
#1617618
05/08/14 02:24 PM
05/08/14 02:24 PM
Posts: 2,928 Canada
RobR
Canada
I have brand new NRC distributors never been used..Blue and Natural.. Do you remember what they were worth NEW...$795.00 What do these guys want for their old dist??? I'll sell you one for what I have into them.. I use one on my low deck.
[Re: Al_Alguire]
#1617619
05/08/14 03:15 PM
05/08/14 03:15 PM
Posts: 1,403 Chesterfield Twp. Mi.
John Burdine
Jesel belt drive with distributor...hmm...maybe i'll sell my car and buy one...oh wait...then I wont have anything to put it on...thanks AL!
[Re: Al_Alguire]
#1617620
05/08/14 03:22 PM
05/08/14 03:22 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Dont those only work if you have a timing belt?
[Re: Jeepmon]
#1617621
05/08/14 03:31 PM
05/08/14 03:31 PM
John Burdine
Yep. I think the set-up runs about $1700.
not sure if the MSD cap adapt fits the big mopar pro billet or if it will clear the valve cover. anyone?
[Re: 70satelliteguy]
#1617628
05/09/14 12:02 AM
05/09/14 12:02 AM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I am currently using an older Mopar MSD distributor(part# 8536) which uses a Chevrolet distributor cap! I don't know if they are available anymore but it works great for me. I run a crank trigger and the MSD Digital multi- retard box and phase my rotor 1/2 way between my maximum retard. Mike
I have that style dist on mine too with the adjustable rotor and cap-a-dapt that uses the big Ford cap.
I'm pretty sure the cap-a-dapt and rotor are out of production at least for that distibutor.
Kevin
[Re: Monte_Smith]
#1617630
05/10/14 11:58 AM
05/10/14 11:58 AM
Posts: 5,875 communist bloc of new jersey
jamesc
While nice, the large cap is not a must. Just keep the initial low, use a crank trigger, phase the rotor in the right spot and you will never have an issue
Monte
that's what i was thinking plus i always run a locked out crank trigger. if you have things set up right there shouldn't be an issue even if you're modifying the timing downtrack
