Will these heads work? #1617299
05/06/14 11:18 PM
05/06/14 11:18 PM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
Will the 4027596 heads fit into a 360 magnum block?
Re: Will these heads work? [Re: KY Charger] #1617300
05/06/14 11:31 PM
05/06/14 11:31 PM
Yes the sb/mag heads will swap. As you know there are differences but they will bolt on with the same head gaskets/block & head bolt pattern. I believe you'll need LA head bolts since using mag neads on an LA short block requires mag head bolts (I'm in the middle of that swap)
