repair brake booster? #1615094
05/02/14 04:56 PM
05/02/14 04:56 PM
Detroit, MI
GetAwayDriver Offline OP
Detroit, MI
I have a 1951 Imperial power brake booster which has been in/op since I bought the car. I just disassembled the thing and found a small hole at the edge of the rubber diaphragm.
This isn't the type of car where parts just grow on trees. The rest of diaphragm is in fine shape. Has anyone ever "patched" one of these?
Re: repair brake booster? [Re: GetAwayDriver] #1615095
05/02/14 05:05 PM
05/02/14 05:05 PM
Detroit, MI
Detroit, MI
Um, sorry... Wrong photo in first post!
Re: repair brake booster? [Re: GetAwayDriver] #1615096
05/02/14 05:14 PM
05/02/14 05:14 PM
P
Paul_Fancsali Offline
P
Power brake booster are rebuilt in many larger city's google it
Re: repair brake booster? [Re: Paul_Fancsali] #1615097
05/02/14 05:50 PM
05/02/14 05:50 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
Call Arizona Brake and Clutch when you come out for the RC we deal with them thru work
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: repair brake booster? [Re: azmopar] #1615098
05/02/14 06:58 PM
05/02/14 06:58 PM
Detroit, MI
Detroit, MI
All good ideas, but I'm looking to button this thing back up this weekend, so I figured I'd try something like a bike tube patch. If it doesn't work/last, no harm, I'll pull it back off. It's no where near as hard to remove on a '51 Imp compared to a "modern" car from the 60's. I have it torn down to fix the master cylinder... More important than the booster!
Re: repair brake booster? [Re: GetAwayDriver] #1615099
05/02/14 07:18 PM
05/02/14 07:18 PM
Andrewh Offline
Andrewh  Offline
might try a music store.
accordian bellows repair, or a camera store for the older camera repair.
a tube patch might not hold, or not for long. that looks like a part that bends a lot.
Re: repair brake booster? [Re: Andrewh] #1615100
05/03/14 12:36 AM
05/03/14 12:36 AM
IN
ahy Offline
ahy  Offline
IN
If you try a patch, make sure it is on the pressure (atmosphere) side and not the vacuum side. Good luck and please post how it turns out.
Re: repair brake booster? [Re: ahy] #1615101
05/05/14 12:46 AM
05/05/14 12:46 AM
Detroit, MI
Detroit, MI
Just thought I'd mention that I did patch the hole, (Guitar Center does not carry accordian parts). I used a tire patch on the pressure side and sealed around both with clear RTV. It seemed fairly strong. However, during reassembly, I noticed another problem with an unobtainium part called a "main cylinder" (not the master). The power part of these brakes now goes on the back burner, as conversion to non-power is as easy as one line that bypasses the power unit. That allows me to drive the car with manual brakes as I've done since I bought it.
So it will be a while until I can report success or failure.
Re: repair brake booster? [Re: GetAwayDriver] #1615102
05/05/14 08:16 AM
05/05/14 08:16 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I tried to repair the diaphragm in a Bendix Hydrovac on an International 1600 Loadstar I had with a tire patch. Didn't work. The tire patch separated from the diaphragm. But did it fail because of incompatibility or did I do something wrong? Don't know. Bought a new unit.
