Re: steering shaft 77 w150 4x4
[Re: Mopar2DBone]
#1614929
05/03/14 12:34 AM
05/03/14 12:34 AM
Posts: 511 AZ.
696pack
AZ.
Are you talking about the rag joint? Where the shaft is booked together?
No, the rag joint is at the bottom of the steering shaft next to the steering gear box. This is on the other end of the shaft closer to the firewall and around the shaft is a collar with rubber in it. It is allowing play in the steering. I have a new steering gear box so the play is not there.
[Re: Mopar2DBone]
#1614937
05/03/14 06:25 PM
05/03/14 06:25 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Unless I'm missing something there are only two joints on the shaft.. The rag joint (closest to firewall) and the coupling joint (closest to steering gear).. what am I missing?
Earlier trucks had these reversed, the rag joint was near the steering box, and a different sort of joint was up near the firewall. His may have been factory, or it may have been swapped in.
A lot of guys like the earlier style because they are more forgiving with lifts, or bigger tires.
[Re: hp383]
#1614939
05/03/14 07:34 PM
05/03/14 07:34 PM
Posts: 511 AZ.
696pack
AZ.
In your picture at the top end of the shaft (near firewall) you see the corrigated rubber boot this is the area I am speaking of. Mine does not have the boot (may just be gone) but I think you will find under the boot the shaft is surrounded by rubber, which on mine is worn out causing the play.
To back up a ways. My truck is an original 1978 LRET that has been converted to 4x4 by using the frame of a 1977 W150 and there of course are a mixing of parts to make this conversion work so I am not sure (but think so) if the 1977 steering shaft was used.
[Re: 696pack]
#1614940
05/03/14 11:38 PM
05/03/14 11:38 PM
Posts: 3,884 Oregon
hooziewhatsit
My truck was just like that, and I found a Borgeson shaft that bolted in place. I can find the part number later if you want. Edit: This one http://www.summitracing.com/parts/brg-000940/overview/In theory, where it says 'steering box shaft diameter 3/4" and 36 spline' should match what you have coming out of the column. There is a coupler rebuild kit available for ~$20, which did NOT match the coupler I had. My only real option was the borgeson shaft.
[Re: Elwenil]
#1614942
05/12/14 05:34 AM
05/12/14 05:34 AM
Posts: 511 AZ.
696pack
AZ.
[Re: Elwenil]
#1614943
05/17/14 12:22 AM
05/17/14 12:22 AM
Posts: 511 AZ.
696pack
AZ.
Incorrect. The old style joint is very similar to the later joint and uses two shoes inside pivoting on a pin to engage the body. If the shoes are worn, it will cause a lot of slack in the shaft. Since the shoes are square, and typically have not been rotated yet, you can usually rotate them 90° and put them on new wear surfaces. If they are worn all around, you can replace them with GM or Jeep parts as those are commonly available.
I have been trying to find this part by application of my truck and NAPA and O'Reily's don't have it listed. Any help appreciated.
