steering shaft 77 w150 4x4 #1614927
05/02/14 01:51 AM
05/02/14 01:51 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Are these available new or re-buildable? Mine has play at the end closest to the firewall--the rubber around the shaft.
Re: steering shaft 77 w150 4x4 [Re: 696pack] #1614928
05/02/14 08:15 PM
05/02/14 08:15 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Are you talking about the rag joint? Where the shaft is booked together?
Re: steering shaft 77 w150 4x4 [Re: Mopar2DBone] #1614929
05/03/14 12:34 AM
05/03/14 12:34 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
No, the rag joint is at the bottom of the steering shaft next to the steering gear box. This is on the other end of the shaft closer to the firewall and around the shaft is a collar with rubber in it. It is allowing play in the steering. I have a new steering gear box so the play is not there.
Re: steering shaft 77 w150 4x4 [Re: 696pack] #1614930
05/03/14 12:40 AM
05/03/14 12:40 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sounds like a different layout than the all too common coupler, by steering box that develops slop on almost all of the older trucks.
Re: steering shaft 77 w150 4x4 [Re: 696pack] #1614931
05/03/14 12:55 AM
05/03/14 12:55 AM
Virginia
E
Elwenil Offline
Elwenil  Offline
E
Virginia
The stock shaft on the older trucks is reversed and uses a joint more common on GM trucks and Jeeps. Take it loose and rotate the square shoes 90°, that is usually enough to tighten the joint up.
Re: steering shaft 77 w150 4x4 [Re: 696pack] #1614932
05/03/14 01:02 AM
05/03/14 01:02 AM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Re: steering shaft 77 w150 4x4 [Re: Mopar2DBone] #1614933
05/03/14 01:03 AM
05/03/14 01:03 AM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Sounds like rag joint to me.. See above link..... ^^^^^^^^^^^
Re: steering shaft 77 w150 4x4 [Re: Mopar2DBone] #1614934
05/03/14 01:26 AM
05/03/14 01:26 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
It sounds like he's talking about the lower column bushing .
Re: steering shaft 77 w150 4x4 [Re: mopwrd340] #1614935
05/03/14 05:39 PM
05/03/14 05:39 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
It is NOT the rag joint. I guess I will have to take a picture of it and post it so everyone knows what I am referring to.
Re: steering shaft 77 w150 4x4 [Re: 696pack] #1614936
05/03/14 06:12 PM
05/03/14 06:12 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Unless I'm missing something there are only two joints on the shaft.. The rag joint (closest to firewall) and the coupling joint (closest to steering gear).. what am I missing?
Re: steering shaft 77 w150 4x4 [Re: Mopar2DBone] #1614937
05/03/14 06:25 PM
05/03/14 06:25 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Earlier trucks had these reversed, the rag joint was near the steering box, and a different sort of joint was up near the firewall. His may have been factory, or it may have been swapped in.
A lot of guys like the earlier style because they are more forgiving with lifts, or bigger tires.
Re: steering shaft 77 w150 4x4 [Re: hp383] #1614938
05/03/14 06:39 PM
05/03/14 06:39 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
That makes perfect sense.. Thanks for classifying. My bad..
Re: steering shaft 77 w150 4x4 [Re: hp383] #1614939
05/03/14 07:34 PM
05/03/14 07:34 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
In your picture at the top end of the shaft (near firewall) you see the corrigated rubber boot this is the area I am speaking of. Mine does not have the boot (may just be gone) but I think you will find under the boot the shaft is surrounded by rubber, which on mine is worn out causing the play.
To back up a ways. My truck is an original 1978 LRET that has been converted to 4x4 by using the frame of a 1977 W150 and there of course are a mixing of parts to make this conversion work so I am not sure (but think so) if the 1977 steering shaft was used.
Re: steering shaft 77 w150 4x4 [Re: 696pack] #1614940
05/03/14 11:38 PM
05/03/14 11:38 PM
hooziewhatsit Offline
My truck was just like that, and I found a Borgeson shaft that bolted in place.
I can find the part number later if you want.
Edit: This one http://www.summitracing.com/parts/brg-000940/overview/
In theory, where it says 'steering box shaft diameter 3/4" and 36 spline' should match what you have coming out of the column.
There is a coupler rebuild kit available for ~$20, which did NOT match the coupler I had. My only real option was the borgeson shaft.
Re: steering shaft 77 w150 4x4 [Re: 696pack] #1614941
05/04/14 05:44 PM
05/04/14 05:44 PM
Virginia
E
Elwenil Offline
Elwenil  Offline
E
Virginia
Incorrect. The old style joint is very similar to the later joint and uses two shoes inside pivoting on a pin to engage the body. If the shoes are worn, it will cause a lot of slack in the shaft. Since the shoes are square, and typically have not been rotated yet, you can usually rotate them 90° and put them on new wear surfaces. If they are worn all around, you can replace them with GM or Jeep parts as those are commonly available.
Re: steering shaft 77 w150 4x4 [Re: Elwenil] #1614942
05/12/14 05:34 AM
05/12/14 05:34 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Thank you.
Re: steering shaft 77 w150 4x4 [Re: Elwenil] #1614943
05/17/14 12:22 AM
05/17/14 12:22 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
I have been trying to find this part by application of my truck and NAPA and O'Reily's don't have it listed. Any help appreciated.
Re: steering shaft 77 w150 4x4 [Re: 696pack] #1614944
05/17/14 01:14 AM
05/17/14 01:14 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
You are out of luck. That was a component shaft as far as I can remember. 72-77 were close to the same. 78 was on its own. 78 is almost a 77 reversed end for end but again as I recall different. 79-93 has the failure prone coupler which Borgeson makes a replacement. Get the 77 part numbers and just maybe some car parts will supersede.
