engine quest heads?? magnum hybrid #161420
12/05/08 12:07 AM
12/05/08 12:07 AM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
Has anyone used these heads and what do they cost, I was thinking of using instead of getting used magnum heads rebuilt? Any idea's??
thanks kurt
Re: engine quest heads?? magnum hybrid [Re: kams] #161421
12/05/08 09:40 AM
12/05/08 09:40 AM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Good idea.. I got a set bare for less than $500... Clearwater cylinder head runs them on ebay for a very good price. I have them on my 390 stroker and they are good quality castings and make decent power... These heads will make more power than any non W2 iron stock small block casting... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: engine quest heads?? magnum hybrid [Re: tpabayflyer] #161422
12/05/08 01:54 PM
12/05/08 01:54 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
contact CMEngines.com, they're a distributor, and the prices quoted to me were cheaper than Clearwater. earlier this year they quoted me ~$650/pr assembled with new OEM spec valves and GM3100 springs, or $850/pr assembled with SB chev +.1" valves and springs for a hydraulic roller good to .55" lift......(prices don't include shipping)
2017 Grand Cherokee Overland
Re: engine quest heads?? magnum hybrid [Re: tpabayflyer] #161423
12/05/08 08:30 PM
12/05/08 08:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They are a real nice head for the price. I had a good experiance with Clearwater cylinder head.
I got to disagree though about the best non W2 iron head. I like the RHS and R/T better however they are both discontinued and were not huge improvements over the EQ, just a little better.
Re: engine quest heads?? magnum hybrid [Re: HotRodDave] #161424
12/05/08 09:30 PM
12/05/08 09:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
read over in the racing forum..that Indy is working with RHS to produce an iron head that can be machined for either LA shafts or magnum studs.
it is listed un Predator Heads...it is the first posting..
Tony
70 AARCuda Vitamin C
Re: engine quest heads?? magnum hybrid [Re: kams] #161425
12/06/08 01:14 AM
12/06/08 01:14 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
This is a great head. Higher nickel content. Great flow when ported properly. More forgiving than an aluminum head. Use a Comp rocker or Jesel rocker arm if the budget allows. Stay away from FBO as a source. Queat Ind. is an international smelter and produces high quality auto parts.
Re: engine quest heads?? magnum hybrid [Re: patrick] #161426
12/06/08 07:42 AM
12/06/08 07:42 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Any measurements of the cc's of the combustion chambers?
Any guesses as to how many thousandths the decks could be milled?
If CME can supply different valve combos
any chance that they would fit
hollow exhaust valves with sodium filling?
Re: engine quest heads?? magnum hybrid [Re: 360view] #161427
12/06/08 07:55 AM
12/06/08 07:55 AM
USA
3
360view Offline
360view  Offline
3
USA
Re: engine quest heads?? magnum hybrid [Re: 360view] #161428
12/06/08 04:47 PM
12/06/08 04:47 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
probably if you have the $$.....
Re: engine quest heads?? magnum hybrid [Re: patrick] #161429
12/06/08 05:08 PM
12/06/08 05:08 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Here is a pic of my EQ heads after porting and the 2.02 intake.... TBF
Re: engine quest heads?? magnum hybrid [Re: tpabayflyer] #161430
12/06/08 05:12 PM
12/06/08 05:12 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I don't know how much better the 2.02 valve is compared to stock size but I bought them bare and had to buy valves so there was no big difference in cost so I upgraded to the 2.02 size. It looks like shrouding is definately an issue to a point but I think it still flows better than the 1.92 intake as some flow bench results show..... overall, I like these heads and feel that for a not to racy street/strip combo these heads are hard to beat. TBF
Re: engine quest heads?? magnum hybrid [Re: 360view] #161431
12/06/08 06:51 PM
12/06/08 06:51 PM
Crowley,TX
70Duster360 Offline
super street
70Duster360  Offline
super street
Crowley,TX
"Any measurements of the cc's of the combustion chambers?"
I have a set on my 408". The chambers are rated at 62 cc's but mine measured 58 cc's.
Re: engine quest heads?? magnum hybrid [Re: 70Duster360] #161432
12/07/08 07:21 AM
12/07/08 07:21 AM
USA
3
360view Offline
360view  Offline
3
USA
thanks for posting that 58 cc measurement
Re: engine quest heads?? magnum hybrid [Re: 360view] #161433
12/07/08 01:51 PM
12/07/08 01:51 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I have been pondering the use of Magnum type heads from EQuest. Price wise, does the conversion come out the same as using the Edelbrock LA type heads? The Eddies cost more but I can reuse my pushrods and rocker arms/shafts. The Magnums Id buy from Clearwater are $900/pair but Id have to puy the pushrods, lifters and rocker arms to complete the conversion. Both heads I believe would require new head bolts?? Do I save any money with the heads from Clearwater when all is said and done?
Keep old mopars alive.
Re: engine quest heads?? magnum hybrid [Re: 2boltmain] #161434
12/07/08 02:16 PM
12/07/08 02:16 PM
Northern Indiana
capac Offline
capac  Offline
Northern Indiana
The ONLY reason I'm not using a magnum style head is the cam lift restriction.... eddies for me.
'64 390 Valiant Signet Convertable (WIP...)
Re: engine quest heads?? magnum hybrid [Re: capac] #161435
12/07/08 02:56 PM
12/07/08 02:56 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I believe the lift limit is due to the valvesprings the E Quest heads come with. The head for $450/ea has a limit of .500". The cam I already have is .514" so additional springs will add more $$$ to the conversion cost.
Re: engine quest heads?? magnum hybrid [Re: 2boltmain] #161436
12/07/08 03:20 PM
12/07/08 03:20 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
.565 lift here... Comp XE-275HL with .525 lift and 1.6 rockers.... works good TBF
Re: engine quest heads?? magnum hybrid [Re: tpabayflyer] #161437
12/07/08 03:39 PM
12/07/08 03:39 PM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
what springs are you using?
Re: engine quest heads?? magnum hybrid [Re: 84Stepside] #161438
12/07/08 07:04 PM
12/07/08 07:04 PM
Jax, Florida
1976duster Offline
1976duster  Offline
Jax, Florida
Re: engine quest heads?? magnum hybrid [Re: 84Stepside] #161439
12/07/08 10:34 PM
12/07/08 10:34 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I believe they are the the mopar 6062 springs??? They are the high lift version for magnums and they are a single spring and they are tight! TBF
