Re: Need help picking a turbo plz
[Re: MNobody]
#1614196
05/06/14 04:08 PM
05/06/14 04:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
fpr part number 13301 aeromotive 3-65 psi 136.00 summit or jegs
Yep i seen that one but it doesn't have a gauge port or is there another way to connect a gauge under the hood? Thanks!
T a gauge in at the carb
[Re: MR_P_BODY]
#1614197
05/06/14 08:47 PM
05/06/14 08:47 PM
Posts: 4,884 Michigan
MNobody
I'm an idiot, the T i have that splits the carb line has the gauge in it, for some reason i thought the gauge screwed into the regulator.....
[Re: MNobody]
#1614199
05/06/14 09:38 PM
05/06/14 09:38 PM
MR_P_BODY
Any point down stream of the reg is the same pressure
[Re: all spooled up]
#1614205
05/07/14 12:10 AM
05/07/14 12:10 AM
MNobody
if your looking for 500 hp u need a 83 gph gallons per hour to make 500 hp. the expert blow thr carb guys say fuel pressure 7 psi at idle; say 10 psi boost, 6 psi for line loses for bends turns ext in your fuel line system to carb. so for 10 psi of boost you should be able to have 23 psi fuel pressure and 83 gph.. I donot know on your 318 but I think u whould need about 10 pounds of boost to make 500 hp
Well i'll pick one along that line, thanks!
[Re: MNobody]
#1614206
05/07/14 01:57 AM
05/07/14 01:57 AM
Posts: 121 mid-mich
turboplymouth
mid-mich
I've been using the 255 walbro and mallory 4309 reg. for years, -8 feed and return with no pressure creep problems. You are going to want a gauge to read while driving to verify the pressure is increasing with boost.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj.
9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
[Re: turboplymouth]
#1614207
05/07/14 10:57 AM
05/07/14 10:57 AM
MNobody
Thanks for the info, didn't think of a gauge inside that would be a must. Frickin fuel pumps are expensive
Re: Update
[Re: MNobody]
#1614209
05/25/14 01:21 AM
05/25/14 01:21 AM
MNobody
Got the 2 in 1 done With the Turbo in place i have 1 1/2" hood clearance to the compressor housing is that ok? Enough room to get a blanket on it?
Also can i mount the wastegate toward the front of the pipe that the turbo flange is mounted to? thanks!
Re: Update
[Re: MNobody]
#1614210
05/25/14 01:33 AM
05/25/14 01:33 AM
MR_P_BODY
I dont want to tell you what to do... but throw that in the trash... get some mandrel bent tubing and Y it together.. dont run a T like that and how thick is that turbo flange.. maybe 1/4".. make it thicker or its just gonna worp all to hell
Re: Update
[Re: MR_P_BODY]
#1614211
05/25/14 11:18 AM
05/25/14 11:18 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
I got a chuckle out of that pic. I love the parts store crinkle bend exhaust tubing! From reading this thread it seems it should be called boosting on a budget... And yes, definitely Y the merge point.
Re: Update
[Re: GTS340]
#1614212
05/25/14 11:32 AM
05/25/14 11:32 AM
MR_P_BODY
He is gonna need a expansion coupler in between the 2 sides so it doesnt crack the two when it heats and cools
