Page 3 of 5 1 2 3 4 5
Re: Need help picking a turbo plz [Re: MR_P_BODY] #1614176
05/01/14 11:31 PM
05/01/14 11:31 PM
MNobody Offline OP
MNobody  Offline OP
Your gonna break that little Rampage lol my brother had one years ago, cool little trucks. I'm over near Jackson.
Naa...its a moly tube chassis
Does it still have the 4 in it or did you squeeze something else in there?
There isnt any bed in the back... I put a 416 in it..
should run 9.80 - 10.0
Thats gotta be fun!
Re: Need help picking a turbo plz [Re: MNobody] #1614177
05/02/14 12:14 AM
05/02/14 12:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Good luck on your build, hope it works out. Just food for thought. That budget ugly 62 Savoy 4 door has gone fairly quick with a nearly stock 360. 10.08@136 with a 3.23 gear in street trim at 3700lbs.
Doug
Re: Need help picking a turbo plz [Re: dvw] #1614178
05/02/14 12:36 AM
05/02/14 12:36 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Can anybody plot the range and trajectory of a carburetor after it goes thru the hood under a 10 PSI of boost backfire? 20 PSI?
What would the effect be steel vs 'glass hood, right vs left carb?
Seriously, quickd100 has had some success blowing up a 318 with a draw thru running a single Thermoquad and making the numbers you are looking for and then some.
https://board.moparts.org/ubbthreads/show...rue#Post8039781
Kevin
I found if you use the Mopar factory accelerator cable will keep it from going very far.
Doug
I forgot about the OEM carb tether system.
Does that pass NHRA tech or do you require an additional "approved" one?
Kevin
Re: Need help picking a turbo plz [Re: dvw] #1614179
05/02/14 01:11 AM
05/02/14 01:11 AM
MNobody Offline OP
MNobody  Offline OP
Good luck on your build, hope it works out. Just food for thought. That budget ugly 62 Savoy 4 door has gone fairly quick with a nearly stock 360. [Email]10.08@136[/Email] with a 3.23 gear in street trim at 3700lbs.
Doug
Sounds fairly quick enough for me, i have a spare 742 case with 3:23 gears waiting myself, thanks for the info!
Re: Need help picking a turbo plz [Re: MR_P_BODY] #1614180
05/02/14 01:14 PM
05/02/14 01:14 PM
MNobody Offline OP
MNobody  Offline OP
I finaly agreed to go blow through and my Naysayers disappeared? I guess i'll give up my nightmare and just go single turbo single carb blow through financialy it will get on the road quicker.
Re: Need help picking a turbo plz [Re: MNobody] #1614181
05/02/14 01:19 PM
05/02/14 01:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A very good choice... with that set up you can/will
have help from people that have or are running the same
style package... plus you get a larger choice of turbos
Re: Need help picking a turbo plz [Re: MR_P_BODY] #1614182
05/02/14 02:25 PM
05/02/14 02:25 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I think you will be better off. Hope you take pics and post em.
Re: Need help picking a turbo plz [Re: FastmOp] #1614183
05/02/14 07:18 PM
05/02/14 07:18 PM
MNobody Offline OP
MNobody  Offline OP
Member 67 Satelite is going to sell me his Gt42, sounds like that will do the job, thanks!
Still waitin on my buddys to recommend a pump,regulator, and so on. Lol. I have -8 from the cell do i need that big as a return or can i go to -6 ?
Re: Need help picking a turbo plz [Re: MNobody] #1614184
05/02/14 07:29 PM
05/02/14 07:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its always best to match the supply line or go larger
so you dont make too much pressure in the return...
just get a boost reference regulator... I have a Mallory
thats boost referenced on my NA set up already for
when I change over
Re: Need help picking a turbo plz [Re: MR_P_BODY] #1614185
05/02/14 08:01 PM
05/02/14 08:01 PM
MNobody Offline OP
MNobody  Offline OP
when I change over
Lol that thing is gonna be crazy, how much does it weigh?
Ok on the regulator, now i was looking at 140 gph pumps but what pressure will it need to be? Or Can i hook 2 holley blue's together to get 28 psi
Re: Need help picking a turbo plz [Re: MNobody] #1614186
05/02/14 08:12 PM
05/02/14 08:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
when I change over
It should in the 2800#-2900# range... no you cant
parallel 2 holleys to get 28#...when you do that you
gain flow.. not pressure... since your going to run
a carb you need flow but maintain the 7-71/2 psi..
if you go injected you need in the 50# range
Re: Need help picking a turbo plz [Re: MR_P_BODY] #1614187
05/02/14 08:32 PM
05/02/14 08:32 PM
ohio
all spooled up Offline
ohio
for the pump u need 6 psi at idle and 1 psi for each pound of boost so 10 pounds of boost is a min 16 psi fuel pressure and a boost reference fuel pressure regulator with return min - 8an line
Re: Need help picking a turbo plz [Re: all spooled up] #1614188
05/02/14 10:23 PM
05/02/14 10:23 PM
MNobody Offline OP
MNobody  Offline OP
Gotcha Thanks!
Re: Need help picking a turbo plz [Re: Duner] #1614189
05/02/14 10:27 PM
05/02/14 10:27 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
On my turbo car, everytime I dropped compression the spool got better and it made more power everywhere.
I am in the process of dropping from 8.5 to 7.8.
It seems counterintuitive but on a boosted car the lower the CR the better.
I wonder how much of that perceived better spool was because the engine was already working so much harder just to run that it was already on the threshold of building boost?
Was that on a V8 engine?
I'd like to dig into this further when I have more time but I will add this:
I have had my own dynos for almost 10 years so I test every change I make to my car. The power curve started higher and earlier with nothing more than an comp change, it was 400 rpm earlier and 28 rwhp or so higher , same turbo, same tune, same boost controller.
The car was a rotary, but its still a 4 stroke motor. The comp change makes the total volume of the cylinder or chamber larger.
Dave Vizard wrote a lot about this in his books, and was the deciding factor for me to take the motor apart to go down to 8.5:1 from 9:1. I put his theories to the test and its proven itself. The interesting thing is the 8.5:1 rotors are actually heavier than the the 9:1 rotors, and the engine still made more power with the 8.5's.
When he says on the cover, speed secrets for any engine , he isn't kidding.
Re: Need help picking a turbo plz [Re: Uberpube] #1614190
05/03/14 12:19 AM
05/03/14 12:19 AM
MNobody Offline OP
MNobody  Offline OP
Sounds good to me, lower compression i got
Re: Need help picking a turbo plz [Re: MNobody] #1614191
05/03/14 11:44 AM
05/03/14 11:44 AM
MNobody Offline OP
MNobody  Offline OP
67 Satelite put the Turbo in the mail headin my way and i havn't even paid the man yet. That's what's best about Mopar people
Re: Need help picking a turbo plz [Re: MNobody] #1614192
05/06/14 11:21 AM
05/06/14 11:21 AM
MNobody Offline OP
MNobody  Offline OP
Re: Need help picking a turbo plz [Re: MNobody] #1614193
05/06/14 11:44 AM
05/06/14 11:44 AM
MNobody Offline OP
MNobody  Offline OP
Geez, can't find an affordable return style ,boost referenced regulator with a gauge port that goes low enough for a carb,Any suggestions gentlemen? Ty.
Re: Need help picking a turbo plz [Re: MNobody] #1614194
05/06/14 11:54 AM
05/06/14 11:54 AM
ohio
ohio
fpr part number 13301 aeromotive 3-65 psi 136.00 summit or jegs
Re: Need help picking a turbo plz [Re: all spooled up] #1614195
05/06/14 04:05 PM
05/06/14 04:05 PM
MNobody Offline OP
MNobody  Offline OP
Yep i seen that one but it doesn't have a gauge port or is there another way to connect a gauge under the hood? Thanks!
