Page 4 of 5 1 2 3 4 5
Re: Need help picking a turbo plz [Re: MNobody] #1614196
05/06/14 04:08 PM
05/06/14 04:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
fpr part number 13301 aeromotive 3-65 psi 136.00 summit or jegs
Yep i seen that one but it doesn't have a gauge port or is there another way to connect a gauge under the hood? Thanks!
T a gauge in at the carb
Re: Need help picking a turbo plz [Re: MR_P_BODY] #1614197
05/06/14 08:47 PM
05/06/14 08:47 PM
MNobody Offline OP
MNobody  Offline OP
I'm an idiot, the T i have that splits the carb line has the gauge in it, for some reason i thought the gauge screwed into the regulator.....
Re: Need help picking a turbo plz [Re: MNobody] #1614198
05/06/14 08:49 PM
05/06/14 08:49 PM
MNobody Offline OP
MNobody  Offline OP
Re: Need help picking a turbo plz [Re: MNobody] #1614199
05/06/14 09:38 PM
05/06/14 09:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Any point down stream of the reg is the same pressure
Re: Need help picking a turbo plz [Re: MNobody] #1614200
05/06/14 09:44 PM
05/06/14 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How about this pump?
http://www.summitracing.com/parts/pfs-70150/overview/
It could be marginal... as you add pressure you reduce
flow rate... so it might be a issue depending on
how much boost you plan on and rpm
Re: Need help picking a turbo plz [Re: MR_P_BODY] #1614201
05/06/14 11:05 PM
05/06/14 11:05 PM
MNobody Offline OP
MNobody  Offline OP
How about this one
http://www.summitracing.com/parts/vpn-gsl392bx/overview/
Re: Need help picking a turbo plz [Re: MNobody] #1614202
05/06/14 11:11 PM
05/06/14 11:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How about this one
To be honest you dont need that pressure but you want
flow... will it work.. yes but thats a lot of wasted
pressure so you need a good return(big)
Re: Need help picking a turbo plz [Re: MNobody] #1614203
05/06/14 11:16 PM
05/06/14 11:16 PM
ohio
all spooled up Offline
ohio
How about this one
that one will work, for what you are doing, lots of mild to medimum v8 blow tru guys use those
Re: Need help picking a turbo plz [Re: all spooled up] #1614204
05/06/14 11:53 PM
05/06/14 11:53 PM
ohio
ohio
if your looking for 500 hp u need a 83 gph gallons per hour to make 500 hp. the expert blow thr carb guys say fuel pressure 7 psi at idle; say 10 psi boost, 6 psi for line loses for bends turns ext in your fuel line system to carb. so for 10 psi of boost you should be able to have 23 psi fuel pressure and 83 gph.. I donot know on your 318 but I think u whould need about 10 pounds of boost to make 500 hp
Re: Need help picking a turbo plz [Re: all spooled up] #1614205
05/07/14 12:10 AM
05/07/14 12:10 AM
MNobody Offline OP
MNobody  Offline OP
Well i'll pick one along that line, thanks!
Re: Need help picking a turbo plz [Re: MNobody] #1614206
05/07/14 01:57 AM
05/07/14 01:57 AM
mid-mich
turboplymouth Offline
mid-mich
I've been using the 255 walbro and mallory 4309 reg. for years, -8 feed and return with no pressure creep problems. You are going to want a gauge to read while driving to verify the pressure is increasing with boost.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj. 9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
Re: Need help picking a turbo plz [Re: turboplymouth] #1614207
05/07/14 10:57 AM
05/07/14 10:57 AM
MNobody Offline OP
MNobody  Offline OP
Thanks for the info, didn't think of a gauge inside that would be a must. Frickin fuel pumps are expensive
Update [Re: MNobody] #1614208
05/25/14 12:21 AM
05/25/14 12:21 AM
MNobody Offline OP
MNobody  Offline OP
Got the 2 in 1 done
With the Turbo in place i have 1 1/2" hood clearance to the compressor housing is that ok? Enough room to get a blanket on it?
Re: Update [Re: MNobody] #1614209
05/25/14 01:21 AM
05/25/14 01:21 AM
MNobody Offline OP
MNobody  Offline OP
Got the 2 in 1 done
Also can i mount the wastegate toward the front of the pipe that the turbo flange is mounted to? thanks!
Re: Update [Re: MNobody] #1614210
05/25/14 01:33 AM
05/25/14 01:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Got the 2 in 1 done
I dont want to tell you what to do... but throw that
in the trash... get some mandrel bent tubing and Y
it together.. dont run a T like that and how thick is
that turbo flange.. maybe 1/4".. make it thicker or
its just gonna worp all to hell
Re: Update [Re: MR_P_BODY] #1614211
05/25/14 11:18 AM
05/25/14 11:18 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Got the 2 in 1 done
I got a chuckle out of that pic. I love the parts store crinkle bend exhaust tubing! From reading this thread it seems it should be called boosting on a budget...
And yes, definitely Y the merge point.
Re: Update [Re: GTS340] #1614212
05/25/14 11:32 AM
05/25/14 11:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Got the 2 in 1 done
He is gonna need a expansion coupler in between the
2 sides so it doesnt crack the two when it heats and
cools
Re: Update [Re: MR_P_BODY] #1614213
05/25/14 02:32 PM
05/25/14 02:32 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Oh like this?
Re: Update [Re: MR_P_BODY] #1614214
05/25/14 02:39 PM
05/25/14 02:39 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Are you guys trying to deny him the opportunity to learn from mistakes?
Re: Update [Re: dizuster] #1614215
05/25/14 02:47 PM
05/25/14 02:47 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Keep at it. Don't listen to these guys. Your setup is going to really surprise the heck out of yourself. And you will be up and running pretty soon by the looks of it.
