spraying on the tranbrake #1614040
04/30/14 12:03 AM
04/30/14 12:03 AM
Winterpeg, Canada
hvyweight Offline OP
Winterpeg, Canada
Who's doing it and how much?
thanks
Mike
Re: spraying on the tranbrake [Re: hvyweight] #1614041
04/30/14 12:23 AM
04/30/14 12:23 AM
WA
JD Dart Offline
JD Dart  Offline
WA
I don't spray but if I did it would be with a wot switch and a 5 pole relay to energize the noz when the Transbrake single went off.
Re: spraying on the tranbrake [Re: hvyweight] #1614042
04/30/14 12:25 AM
04/30/14 12:25 AM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I wired mine so as soon as the transbrake releases it comes on. I wouldn't want to be on the transbrake with the nitrous on
Re: spraying on the tranbrake [Re: plycuda] #1614043
04/30/14 12:29 AM
04/30/14 12:29 AM
Winterpeg, Canada
Winterpeg, Canada
I have been spraying at the release of the brake. No delay whatsoever. I am think about spraying on the brake to get the car to 60ft better.
Re: spraying on the tranbrake [Re: hvyweight] #1614044
04/30/14 12:53 AM
04/30/14 12:53 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
depending on your hp with the shot on...
hp is hp.. as long as you have the trans and converter to handle power..i dont see any reason you couldnt spray while on the brake..
ive hit mine with a .63 (150hp)pill. while on the brake...(i realise thats not all that much)when my tires are good and track is good it usually stands the front tires up the most..
but its not consistant for me..mostly because it messes up my normal stage and launch routine .
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: spraying on the tranbrake [Re: cheapstreetdustr] #1614045
04/30/14 12:55 AM
04/30/14 12:55 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
why???? I see lots of converters in your future
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: spraying on the tranbrake [Re: bigtimeauto] #1614046
04/30/14 01:18 AM
04/30/14 01:18 AM
Winterpeg, Canada
Winterpeg, Canada
not to sound like a smart azz but why would you say that? Nitrous TS spray on the convertor don't they?
Re: spraying on the tranbrake [Re: hvyweight] #1614047
04/30/14 01:26 AM
04/30/14 01:26 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
My Neon was set to spray .01 second after transbrake release.
2011 Drag Pak Challenger
Re: spraying on the tranbrake [Re: hvyweight] #1614048
04/30/14 01:32 AM
04/30/14 01:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your 60' now with what kind of power... I dont
spray but it makes a TON of torque and with any amount
it would blow through a conv... all the guys I know
that spray pretty hard hit it at the release and ramp
it in for what the track will take... you have to
remember that while your on the line the conv is
making twice the torque and drops as soon as you
start rolling
Re: spraying on the tranbrake [Re: rickseeman] #1614049
04/30/14 01:33 AM
04/30/14 01:33 AM
Winterpeg, Canada
Winterpeg, Canada
did you ever try it on the convertor?
Re: spraying on the tranbrake [Re: hvyweight] #1614050
04/30/14 01:48 AM
04/30/14 01:48 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
If you are going to spray it on the brake I hope you don't use a 2 step if so watch out hood and carb
Re: spraying on the tranbrake [Re: hvyweight] #1614051
04/30/14 01:48 AM
04/30/14 01:48 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
There is absolutely no reason to do this, nor do I know of anybody that does.
Re: spraying on the tranbrake [Re: bigtimeauto] #1614052
04/30/14 02:16 AM
04/30/14 02:16 AM
mi
dirty magnum Offline
mi
did it all the time on micro switch , and 2 way button sprayed 500 to 600 worked great
Re: spraying on the tranbrake [Re: dirty magnum] #1614053
04/30/14 02:24 AM
04/30/14 02:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You hit 500-600 of spray while sitting on the trans
brake... am I hearing you correct
Re: spraying on the tranbrake [Re: MR_P_BODY] #1614054
04/30/14 02:54 AM
04/30/14 02:54 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
Not really the right way to do it. If you are having to go to these extreme measures to get the car to leave, you have some converter problems. This will destroy a converter pretty fast also. If you hate your trans and converter at least video the event for our viewing pleasure later.
Hutch
Re: spraying on the tranbrake [Re: MR_P_BODY] #1614055
04/30/14 03:03 AM
04/30/14 03:03 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Been there, done it, wouldn't recommend it. 60ft improved from 1.30 to 1.28, but it was pretty much the same by the 330ft.! 1.76 glide 9" spragless converter, mild 440 in a 2850 lb. car. 250 at the hit, and occasionally before, then another 175 at 100ft out.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: spraying on the tranbrake [Re: bigtimeauto] #1614056
04/30/14 10:18 AM
04/30/14 10:18 AM
an8sec70cuda Offline
CHIP
'06 GMC 2500HD LBZ Duramax
Re: spraying on the tranbrake [Re: an8sec70cuda] #1614057
04/30/14 01:40 PM
04/30/14 01:40 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
X3
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: spraying on the tranbrake [Re: SB412DUSTER] #1614058
04/30/14 01:51 PM
04/30/14 01:51 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Yeah especially if the engine stalls after the second stage timer has started.
My car is set up for the first stage to start at the transbrake release and the second to start some time after the transbrake is released. Somehow up at STL this happened to Mike Robbins in (now) my Demon when the engine quit as he was staging and he hit the starter...
Re: spraying on the tranbrake [Re: hvyweight] #1614059
04/30/14 02:29 PM
04/30/14 02:29 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
NO............I tune several TS and TD cars. Nobody I know of sprays while on the brake. Why would you?.....If your car won't 60ft where you want it, THIS is not going to fix it. Something is not right in the setup if it won't 60ft
Monte
