Re: spraying on the tranbrake
[Re: hvyweight]
#1614044
04/30/14 12:53 AM
04/30/14 12:53 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
depending on your hp with the shot on... hp is hp.. as long as you have the trans and converter to handle power..i dont see any reason you couldnt spray while on the brake.. ive hit mine with a .63 (150hp)pill. while on the brake...(i realise thats not all that much)when my tires are good and track is good it usually stands the front tires up the most.. but its not consistant for me..mostly because it messes up my normal stage and launch routine .
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: bigtimeauto]
#1614046
04/30/14 01:18 AM
04/30/14 01:18 AM
Posts: 190 Winterpeg, Canada
hvyweight
Winterpeg, Canada
why???? I see lots of converters in your future
not to sound like a smart azz but why would you say that? Nitrous TS spray on the convertor don't they?
[Re: hvyweight]
#1614048
04/30/14 01:32 AM
04/30/14 01:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Whats your 60' now with what kind of power... I dont spray but it makes a TON of torque and with any amount it would blow through a conv... all the guys I know that spray pretty hard hit it at the release and ramp it in for what the track will take... you have to remember that while your on the line the conv is making twice the torque and drops as soon as you start rolling
[Re: dirty magnum]
#1614053
04/30/14 02:24 AM
04/30/14 02:24 AM
MR_P_BODY
did it all the time on micro switch , and 2 way button sprayed 500 to 600 worked great
You hit 500-600 of spray while sitting on the trans brake... am I hearing you correct
[Re: MR_P_BODY]
#1614055
04/30/14 03:03 AM
04/30/14 03:03 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Been there, done it, wouldn't recommend it. 60ft improved from 1.30 to 1.28, but it was pretty much the same by the 330ft.! 1.76 glide 9" spragless converter, mild 440 in a 2850 lb. car. 250 at the hit, and occasionally before, then another 175 at 100ft out.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: bigtimeauto]
#1614056
04/30/14 10:18 AM
04/30/14 10:18 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
There is absolutely no reason to do this, nor do I know of anybody that does.
[Re: SB412DUSTER]
#1614058
04/30/14 01:51 PM
04/30/14 01:51 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
If you are going to spray it on the brake I hope you don't use a 2 step if so watch out hood and carb
Yeah especially if the engine stalls after the second stage timer has started.
My car is set up for the first stage to start at the transbrake release and the second to start some time after the transbrake is released. Somehow up at STL this happened to Mike Robbins in (now) my Demon when the engine quit as he was staging and he hit the starter...
[Re: hvyweight]
#1614059
04/30/14 02:29 PM
04/30/14 02:29 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
NO............I tune several TS and TD cars. Nobody I know of sprays while on the brake. Why would you?.....If your car won't 60ft where you want it, THIS is not going to fix it. Something is not right in the setup if it won't 60ft
Monte
